Carpet Tile And Baseboard Installation - Flooring - DIY Chatroom Home Improvement Forum
Old 12-29-2011, 09:39 AM   #1
Question
Carpet Tile and Baseboard Installation
I am installing carpet tile (TrafficMaster Best Practice commercial grade tile 24"x24") in my new "man room".
It's a small job about 230' sq and I would like to finish off the room with baseboards. I have read that baseboards are typically installed first leaving a gap on bottom of approx 1/4" to leave room for carpeting.
I can see the logic in this to some degree but doesn't it make more sense to install the carpet tiles butted up to the wall and then install the baseboards so they can be brought as close to the top of the carept tile as possible so there is no chance of an unsightly gap between the carpet tile and baseboard?
Thanks,
Shannon
TheMadStrater is offline   Reply With Quote
Old 12-29-2011, 09:44 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
In your case you are correct, - DO IT your way!
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
rusty baker (12-29-2011)
Tags
baseboard , carpet , flooring , moulding , tile
Tile Floor - Tile Baseboard alan45371 Flooring 6 11-07-2011 05:38 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
Tile baseboard with carpet? bpak04 Flooring 2 11-03-2008 12:28 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
Tile Baseboard leted_82 Flooring 3 07-07-2007 11:57 AM
