Carpet Then Base Molding Or What? - Flooring - DIY Chatroom Home Improvement Forum
Old 10-08-2008, 02:01 PM   #1
Rewards Points: 264
Carpet then base molding or what?
Over a new subfloor do I get the carpet installed first or measure up a certain distace from the subfloor and install the molding first?
Jeekinz is offline   Reply With Quote
Old 10-08-2008, 03:56 PM   #2
RippySkippy's Avatar
You can do it either way...but the carpet layers like to have the base down first, it gives them something to tuck the carpet under.
It is easier to lay the base when you have a solid surface to work off of rather than the spring of the carpet. Keep the base 3/8" to 1/2" off the floor with a a plywood scrap as a spacer.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 10-08-2008, 04:37 PM   #3
I prefer to do it the other way. I lay the carpet and then do the molding. This way I can cut the carpeting to the wall and not have to push it under the molding. I did some carpet last week and half the job was with molding and half without. The part without molding was a lot faster and looked just as good.
I think this is one of those things where either way works fine and is more preference than right/wrong.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-10-2008, 09:48 AM   #4
Chagres's Avatar
I like to lay the carpet first, stretch it and hook it to the tack strip, and then install the baseboard. But as the old man used to say, "Each to his own, said the man who kissed the cow!"
Chagres
http://www.icanfixupmyhome.com
Chagres is offline   Reply With Quote
Old 10-10-2008, 12:02 PM   #5
Floorwizard's Avatar
Keep in mind that if you are laying new tack strip and there is no wall moldings, do not install the tack strip too close to the wall or the moldings will pinch the carpet.
Floorwizard is offline   Reply With Quote
base molding and carpet doc70 Flooring 2 04-09-2008 11:33 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
Base molding or carpet first??? Dan N Flooring 5 02-01-2007 08:29 AM
