Forums | Home Repair | Home Improvement | Painting | Interior Decorating | Remodeling | Landscaping
Old 04-16-2014, 04:35 PM   #1
Share |
Carpet Suggestions Nylon & Padding
Hello,
I did some research on carpet, but still have some questions. Carpet will be going in 3 bedrooms, Master, Guest and Back Entertainment Room.
Master: 17.25' x 12'
Guest: 11.42' x 10.7'
Entertainment Room: 17.33' x 14.75'
I looked into Mohawk and Shaw. I was able to go to a local carpet shop and asked to see Shaw 100% Nylon. I felt the Anso Nylon fiber and another called Shaw carpet called Ravishing. I prefer the Ravishing (see below).
http://shawfloors.com/carpetdetails/...6866-spun_silk
Is this good carpet? Any other suggestions. Mohawk was more expensive.
badsha is offline   Reply With Quote
Old 04-16-2014, 06:11 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Ravishing is nylon, so it should wear well and resist stains. The only negative I see is that it's sofbac. I personally don't like sofbac, but some people do. Make sure that you get an experienced installer, sofbac carpets can be difficult to seam and stretch. Also, it is extremely heavy, labor is usually higher because it may take 4 men to carry it in.
To give an example of weight, I have never seen a 12'x12' that I couldn't carry by myself. except a 12'x12' of sofbac usually takes 3 men to carry in.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 04-16-2014, 06:16 PM   #3
Would you recommend any other carpet in Nylon? Which backing do you like?
Old 04-16-2014, 06:49 PM   #4
I like actionbac. But don't let me scare you off. Go to a store and check out the carpet samples and/or rolls. You can see the different backings.
Old 04-16-2014, 07:16 PM   #5
Thank you. I will look at some more carpet. I am getting several quotes right now.
Carpet Opinion nvycrmn Flooring 2 03-22-2014 10:40 PM
Type of Carpet Padding for concrete floor ppeetteerr Flooring 1 03-21-2014 09:18 AM
is there an easy way to remove staples in subfloor from carpet padding? tdeepness Flooring 9 04-18-2010 08:25 PM
Need suggestions from Carpet Contractors (PICS) dcooney Flooring 0 03-10-2010 11:36 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
