Old 11-27-2011, 07:53 AM   #1
Question
Carpet on stairs loose
My contractor installed the carpet on my basement stairs but it looks as if he didn't use a tackless strip. Or if he did carpet is not kicked in to grab it. I want to call him on it, he's been doing some shoddy work lately.
Do you have to use tackless strip on stairs or can you use glue? Shouldn't he of asked my preference?
If carpet not attched to tackless strip will it eventually loosen from stairs, it looks like it's loosing up now.
How would it be fixed?
Trying is offline   Reply With Quote
Old 11-27-2011, 06:53 PM   #2
Is there anyone that can help me?? I've been having terrible luck with contractors and tired being taken advantage of.
Old 11-27-2011, 07:02 PM   #3
Pro Flooring Installer
rusty baker's Avatar
You posted this question twice. There were some answers to the other posting.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
Trying (11-27-2011)
Old 11-27-2011, 07:02 PM   #4
old guy contractor
tcleve4911's Avatar
Did you pay him?
Don't give up your money until you're satisfied.
tcleve4911 is offline   Reply With Quote
The Following User Says Thank You to tcleve4911 For This Useful Post:
Trying (11-27-2011)
Old 11-27-2011, 07:30 PM   #5
I didn't pay him yet.
I just checked under the carpet and there is padding on the stairs but no tackless strip, just staples.
And the landing going to stairs from laminated kitchen floor is not finished with landing tread, just carpet stapled to riser then flat edge of kitchen floor lamnate.
This is the second time he's cut corners on me. He tried to put laminate on concrete floor without leveling floor (he spot leveled it after I complained) or applying underlay/padding and I had to pay him $300 more because he said padding was not in his original estimate. He pulled up laminate but floor still not very good job. He used the cheapest laminate $.66 sq.yd
Should I just pull him from job? I still owe him $2000, job was total $9000 with extras that came up.
Old 11-27-2011, 07:33 PM   #6
My basement was half finished and he's completing it. Was doing great in the beginning then just went down hill. he's been on this job since July.
Old 11-27-2011, 07:52 PM   #7
Thanks for the advise. I'll look up CRI guide to give me some ammunition when I talk to him.
Changing from carpet stairs to wood stairs DIY_user Remodeling 16 07-29-2010 08:16 PM
drywall existing stairs that have carpet Peggers Drywall & Plaster 2 02-20-2010 02:12 AM
Carpet on Stairs, Hallway: Nap Direction Carol Emmarie Flooring 5 03-26-2009 12:40 PM
loose carpet on stairs econdave Flooring 2 06-15-2008 10:29 AM
Carpet on stairs loose econdave General Discussion 4 04-27-2008 07:23 PM
