Carpet On Stair Treads Only??? - Flooring - Page 4 - DIY Chatroom Home Improvement Forum
Old 12-06-2011, 10:04 AM   #46
Rewards Points: 272
Just what Rusty said. Also when working with Berber make sure you use a new blade in your knife, snags in Berber will tend to run away and then you have challenges. I tend to cut all my edges for my seams as this will give you the best end result.
fixrite is offline   Reply With Quote
Old 12-06-2011, 05:50 PM   #47
cocobolo's Avatar
Rewards Points: 5,786
It seems to me that I have read just exactly that.
I did find some decent videos, and the pro installer used his straightedge to make one edge cut. Then he overlapped that over the next edge and ran the loop pile cutter against his straight cut. That way he had matching cuts and then went on to do the seaming.
I have one end of the bedroom cleared out so I will be getting to nail down the tackless shortly and then the real fun will begin.
I'm not sure which pic this is, but I'm hoping it shows the 120 corner where I will be starting.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 12-06-2011, 05:51 PM   #48
cocobolo's Avatar
OK, that's what I was hoping for. I'm going to put the underlay against that wall, and then the carpet will run square off the back wall. I believe that should be OK.
Old 12-06-2011, 06:12 PM   #49
Rewards Points: 272
That will work out just fine. Once you have them cut just so, go ahead and seam them and let it cool. Once that has happened, go ahead and kick the carpet into place.
Old 12-06-2011, 06:15 PM   #50
cocobolo's Avatar
You must have been watching the same videos as me!!!
And I will be using a 50 pound box of tile as my weight to stick the carpet together. One guy just used a small tool box which didn't look like it weighed more than about 15 pounds.
Old 12-06-2011, 06:23 PM   #51
Rewards Points: 272
good thing you are using a box of tiles, sometimes there can be a tendency for the colour from a tool box to transfer to the carpet, that is why I only use grey tool boxes for flooring tools, then I put that on as I seam. No Keith I have not watched any videos on installation of carpet, when I was learning they were not available.
Old 12-06-2011, 06:25 PM   #52
Rewards Points: 272
Keith, when you have some time, check out this link, it is right up your alley http://www.theforgottentechnology.com/newpage1
Old 12-06-2011, 06:29 PM   #53
cocobolo's Avatar
I was kidding when I said that...I knew your experience pre-dated the internet!
Old 12-06-2011, 06:47 PM   #54
Rewards Points: 272
Sorry I tried to import a pic and messed up.
Old 12-06-2011, 07:04 PM   #55
Rewards Points: 272
I just finished my entry way, here is a pic. Hope I did this right.
Old 12-06-2011, 09:22 PM   #56
cocobolo's Avatar
Still not having any luck with your photo...?
Make sure your pic is on your hard drive, re-size it, save as "...", when you go to post click on "manage attachments" below your text box, click on "browse" in the window, click on your pic, open it, upload it - and let it finish uploading before you close that window, close and post.
Send me a pm if it still doesn't work.
Old 12-06-2011, 10:26 PM   #57
Rewards Points: 272
ok,here we go again, one last try. This is my entryway. Just need to grout it,
Old 12-06-2011, 10:43 PM   #58
cocobolo's Avatar
OK, it worked.
Now, I'm curious about that compass like design in the middle...?
Old 12-06-2011, 11:02 PM   #59
Rewards Points: 272
you are correct, it is a compass usually found on maps. What would you like to know about it?
Old 12-07-2011, 12:01 AM   #60
cocobolo's Avatar
It looks like it is made from tile. Did you cut that out yourself, or can you buy such a thing.
Whichever it was, it's pretty neat.
What is the correct way to redo stair treads. John/Suz Flooring 5 10-13-2011 08:11 AM
Carpet upstairs with hardwood stairs ... what to do with top stair? jmai14 Flooring 3 09-10-2011 08:57 PM
2x12 redwood stair treads cracking in center JimmyRrichards Carpentry 4 08-10-2011 10:29 AM
Refacing stair treads Stair newbee Flooring 2 08-10-2010 10:35 PM
New stair treads and flooring rickkeeter Flooring 2 02-24-2010 10:16 PM
