Carpet On Stair Treads Only??? - Flooring - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-27-2011, 02:12 PM   #31
Rewards Points: 272
I guess the only other thing I could mention is too keep pressure on the top of the kicker while kicking, if you fail to do this, then you could end up tearing off the tuffs from the carpet, I do recall many moons ago during my apprentice years I did just that, and the boss was not very happy. Lucky for me it was in a closet.
fixrite is offline   Reply With Quote
Old 11-27-2011, 02:15 PM   #32
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
You can probably just push the carpet tight with the kicker instead of kicking it. Less chance of tearing it and/or banging into the riser. Easier on a newbie's knee too.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 11-27-2011, 02:18 PM   #33
cocobolo's Avatar
Rewards Points: 5,456
Originally Posted by fixrite View Post
I guess the only other thing I could mention is too keep pressure on the top of the kicker while kicking, if you fail to do this, then you could end up tearing off the tufts from the carpet, I do recall many moons ago during my apprentice years I did just that, and the boss was not very happy. Lucky for me it was in a closet.
Yes of course. As you might imagine I have been watching all sorts of videos about this, and that is one thing they do stress.
Just wait 'til I get to the bedroom...500 square feet of totally weird shaped carpet to go down. I figured a little practice on the stairs couldn't hurt.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 11-27-2011, 02:22 PM   #34
cocobolo's Avatar
Good point Rusty. My knees are full of arthritis already, they don't need any more help!
I did see a couple of videos of stair installations. Oddly enough one fellow kicked it pretty hard, and the other pushed it as you suggested. It doesn't seem to matter what you look for regarding carpet installs, there always seems to be two or three different opinions on what or how to do something.
Old 11-27-2011, 02:26 PM   #35
Rewards Points: 272
if you were installing your stairs all in one piece with a heavy carpet then kicking hard in necessary, but for your application of single treads only, then pushing would be sufficient as Rusty pointed out. Oh and don't forget new blades in knife....lol
Old 11-27-2011, 03:01 PM   #36
cocobolo's Avatar
I think I must have been reading your mail fixrite! All the tools I have for the install are brand new. Even bought a proper carpet knife, along with the kicker, seaming iron, loop pile cutter and carpet seam roller.
The only tool I didn't buy is the edge trimmer. For just one room $110 + tax seemed a bit much. If I can't figure out how to cut the edges straight enough then I guess I will need to break down and buy one. I was thinking maybe just lay a straightedge hard up against the wall and cut on top of that with the knife.
Old 11-27-2011, 03:16 PM   #37
Rewards Points: 272
yikes.....that is a lot of money for only one house, if I had known I would of let you use mine, I also have an edge trimmer. If you want you can use my tools and return the others for a refund. I am retired (sort of and don't use them much anymore only for the odd job here and there for friends and family. I live mid island and would be fine with that.
Old 11-27-2011, 04:44 PM   #38
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 11-27-2011, 07:23 PM   #39
cocobolo's Avatar
That's a very generous offer, and I may take you up on the edge trimmer. The other tools I will keep...it's an illness that us tool junkies have. Who knows, when word gets out that I have all these shiny new tools, I may get to use them again here on the island.
Old 12-05-2011, 02:43 PM   #40
cocobolo's Avatar
I've got another quick question about underlay...it's in the bedroom, not on the stairs.
I have read that the underlay and carpet should not run in the same direction, but should be 90 to each other.
Is that correct and why might that be so?
Would it be possible - or should I say acceptable - to have the underlay running at about 30 away from the carpet?
The reason I ask is because two adjoining walls in the bedroom are about 30 away from 90, and I would like to run the underlay up against that wall first.
Old 12-05-2011, 02:51 PM   #41
Rewards Points: 272
the only thing about the underlay is that you should stager your seams and not have them line up with your carpet seams.
Old 12-05-2011, 03:14 PM   #42
Rewards Points: 272
what kind of carpet are you going to be installing? Will you be doing any seaming (ironing)?
Old 12-05-2011, 03:32 PM   #43
Rewards Points: 12
Exactly right.
Old 12-05-2011, 04:55 PM   #44
cocobolo's Avatar
Once again, thanks you guys.
If I run the underlay against the end wall, it would merely cross the carpet joins. It wouldn't be in line at all.
And yes I will be needing two seams about 14' long and two short ones about 3' long. I have an iron for that.
It's a berber carpet, and I'm also aware that I will need the lay of the carpet to run in the same direction. This is what is causing me to have lots of waste carpet...which is going on the stairs.
One more...how far from the walls do I nail the tackless? Most seem to say the width of a strip, another says the thickness of the carpet. Is there any preference?
Old 12-05-2011, 05:49 PM   #45
Rewards Points: 12
Thickness of the carpet.
The Following User Says Thank You to rusty baker For This Useful Post:
cocobolo (12-05-2011)
What is the correct way to redo stair treads. John/Suz Flooring 5 10-13-2011 09:11 AM
Carpet upstairs with hardwood stairs ... what to do with top stair? jmai14 Flooring 3 09-10-2011 09:57 PM
2x12 redwood stair treads cracking in center JimmyRrichards Carpentry 4 08-10-2011 11:29 AM
Refacing stair treads Stair newbee Flooring 2 08-10-2010 11:35 PM
New stair treads and flooring rickkeeter Flooring 2 02-24-2010 11:16 PM
