#226 |
Pro Flooring Installer
Carpet on stair treads only???
Some builders, for some reason, don't fasten the walls to the floor. And the tack strip should hold when you power stretch.
"I'm twisted, not sick. Sick implies, I'll get better" Semi-Retired Installer Installing since 1973 |
#227 | |
Carpet on stair treads only???Quote:
I have seen interior walls where the lazy builder has put just one nail in the bottom plate at each end of a wall. The plate should have nails driven through the plywood into every joist that the wall sits on. Many walls do not end up straight because of something as simple as a crooked bottom plate, so pulling the wall straight and nailing properly eliminates this little annoyance. No wonder people are always saying their house isn't square!
Just an old guy messin' with bits of wood... ...the friendliest thread on the site! Come on by. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to cocobolo For This Useful Post: | BigJim (12-19-2011) |
#228 |
Rusty, I concocted a home brewed stretcher, as HD doesn't have one to rent.
As soon as I moved the hydraulic jack on the stretcher out about 2" that big hump disappeared. Details of the stretcher are on the Gulf Island thread.
| Display Modes | |
| What is the correct way to redo stair treads. | John/Suz | Flooring | 5 | 10-13-2011 09:11 AM |
| Carpet upstairs with hardwood stairs ... what to do with top stair? | jmai14 | Flooring | 3 | 09-10-2011 09:57 PM |
| 2x12 redwood stair treads cracking in center | JimmyRrichards | Carpentry | 4 | 08-10-2011 11:29 AM |
| Refacing stair treads | Stair newbee | Flooring | 2 | 08-10-2010 11:35 PM |
| New stair treads and flooring | rickkeeter | Flooring | 2 | 02-24-2010 11:16 PM |
