Please forgive the delay in responding to the aforementioned drivel. However, this being a Friday evening, my solicitor has been having some difficulty in reaching Mr. Cline's solicitor in order that they make a combined effort to solve the foregoing problem.
It seems that the NFLA has failed to pay their server, which has resulted in a loss of their name on the internet.
We have, however, been able to come up with the North Fork Lovers Association, the North Florida Lawnbowling association, the Nine Fingered Lawyers Association and the Not Frigging Likely Association, none of which seem particularly appropriate to this discussion.
Mr. Cline and myself have agreed to share the position of "Token Smart Ass", as this is a job for only the most experienced individuals. Our solicitors are currently drawing up a suitable agreement in order to facilitate this action.
There is, not surprisingly, a considerable stipend which goes with these positions, and once negotiations on this matter are finalized, our solicitors will be forwarding the bill to you for payment. We sincerely trust that this will not bankrupt you, as neither of us work cheap.
Please ensure that you are not guilty of any further terminological inexactitudes (look it up) and we look forward to a long and fruitful association in future.
, good gravy, does anyone around here speak redneck Blame some of them big words ain't made it this far south yet.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
The Following User Says Thank You to BigJim For This Useful Post:
Oh, so that's what it's called. And here I always thought it was Toilet Zone, silly me.
Just an old guy messin' with bits of wood...
...the friendliest thread on the site! Come on by. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Hey Jim, we're having enough trouble trying to speak our own language, never mind having to learn redneck as well.
But if you have a DVD available to teach us....
The Following User Says Thank You to cocobolo For This Useful Post:
Now if you guys wouldn't mind, I have to get back to work and actually do something today.
First thing I cut the door down to size so it wouldn't be dragging on that high priced carpet. If I remember from my carpentry apprentice days we are supposed to have 1" clearance at the bottom of the door for air changes and whatnot.
I'm quite sure the whatnot is more important than the air changes.
I have noticed something about the knives that I have been using to cut the carpet with...the carpet knife makes one cut and loses its' edge very quickly.
About 15 years ago I bought a package of 100 heavy duty blades from Lee Valley. One of these blades will make many cuts and still seems able to stay very sharp. They fit in any standard utility knife.
I don't know if they still carry this little package, but if they do I highly recommend them. After all these years I still have about 35 or so left. Looks like I will be able to will a few of them to my grandson's when the time comes.
I seamed the three big pieces of carpet this afternoon, after which it is obvious I will need to power stretch the carpet.
The last piece, the one with the dog leg, has a noticeable hump in it, right at the spot where the dog leg runs through the pattern. I think if the carpet can be stretched to the point that the pattern becomes straight it should flatten out.
If you have any suggestions I'm all ears. Thanks.
Keith, when using a power stretcher be sure to place a 2x4 or 2x6 against the wall when using to displace the pressure so as to not put a hole in the wall. There has been situations where walls have been moved by using a power stretcher (generally an inside one). You may also find it necessary to use a few staples to hold the carpet in place if you have to do some extreme stretching.
Yes, I had read about that...I was going to use some 4 x 4's I have here for the purpose.
And I was wondering whether or not that tackless would hold up against the power of a stretcher, and seeing those short tacks that hold it to the floor had me thinking.
I didn't think of using staples, but that would most definitely help.
What if I used the ones in the pic right up against the wall...if they showed after the fact I can always add a baseboard to cover them up.
Something tells me those walls were not supposed to move!
