Carpet On Stair Treads Only??? - Flooring - Page 12 - DIY Chatroom Home Improvement Forum
Old 12-10-2011, 11:35 PM   #166
cocobolo's Avatar
Rewards Points: 6,098
Originally Posted by fixrite View Post
Thanks for the new pics, looks GREAT from my point of view. I think you will be ready for a floor laying apprentiship soon.
Aaaah, I don't think so. Some of the edges don't follow those backing lines, and as a result when you push them together, the pattern on the carpet doesn't look right.
And besides, I plan on retiring from the carpet installation business the second I am finished this job!
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 12-10-2011, 11:40 PM   #167
Rewards Points: 272
It can very daunting laying carpet as Berber is not the most forgiving carpet to install. I am available ( no charge) if you ever feel the need for some help.
fixrite is offline   Reply With Quote
Old 12-10-2011, 11:53 PM   #168
cocobolo's Avatar
Your extreme generosity is showing again...
You know, all my life if I have decided I wanted or needed to do something I would take whatever time it needed to learn how to do whatever it was.
What annoys me about this particular job is that I started out with that big 7" strike against me. But regardless of that, there's no real reason that I cannot do this.
For whatever reason, I'm having the devil of a time getting the carpet to cut straight along one of the pattern rows.
I won't be doing any more trying tonight as the light is simply not good enough in here to see that well.
But tomorrow being another day will hopefully find me in a better frame of mind to get this thing done.
Old 12-10-2011, 11:55 PM   #169
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 148
When you cut with the row follower, make sure that the blade is on the side of the piece you are installing, not on the cutoff side. It will improve the look of the seam.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 12-10-2011, 11:59 PM   #170
Rewards Points: 272
Yes tomorrow will be a better day.
Old 12-11-2011, 12:02 AM   #171
cocobolo's Avatar
Now why the heck couldn't I figure that out for myself?
In places, there are all these horrible little fingers sticking out, doubtless the result of not having the cutter in the proper place.
Many, many thanks for that little tip Rusty.
Old 12-11-2011, 02:12 PM   #172
cocobolo's Avatar
This morning I tried to cut the second side of the middle piece of carpet.
This was a selvedge edge and needed to go back about 1 1/4" to clear some of the mess on the back side, you know...that stuff that looks like it has melted.
So it turns out that it is possible to get a decent cut, and this one came out very well...it's the first cut I'm really happy with. Now if I can just get the adjoining cut to look as good, this will make a good seam.
Still working on the first pair of edges for the first seam. But I wanted to see how it went following Rusty's advice.
Old 12-11-2011, 03:22 PM   #173
cocobolo's Avatar
Finally, a small measure of success.
The two initial edges have now been cut (again) and appear to be fine. What ultimately worked for this was to use a freshly sharpened pair of Chinese scissors...tapped the joint to get the blades tight...and have at it.
Now I have to pray that there is enough carpet that I can pull together so that I don't have spaces against the post or the angled wall.
Old 12-11-2011, 04:13 PM   #174
cocobolo's Avatar
More good news...the carpet has pulled together without incident.
I tried a test seam on some scrap carpet - I'm finally learning - and that seemed almost too easy. No doubt I will run into one pitfall or another.
Then I did the short join by the post, and that presently has a 50lb. box of tile sitting on it.
And now that the first pieces are close enough to join, I'm going to tackle the last piece of carpet at the far end of the room. When I say last...I mean the last big piece. There will need to be a short piece at the extreme far corner, plus whatever section is needed to join in front of the windows.
I think what has made it all work today is the fact that the sun is shining, and I'm a real sun lover. Does wonders for the soul, as well as laying carpet it seems!
Old 12-11-2011, 10:03 PM   #175
cocobolo's Avatar
Perhaps the mystery of the narrow carpet is revealing itself, at least partially.
This is the third and final roll to go down, and it was the first piece to be cut off the original roll at H.D.
The end against the back wall in this pic still measures 11' 4 7/8" wide, as did the other two rolls.
Old 12-11-2011, 10:05 PM   #176
cocobolo's Avatar
This piece of carpet is 23' long, and about 13' out from the wall, or only 10 feet from the beginning of the original roll at H.D., it now has grown to measure 11' 11", not far off what it should be.
Old 12-11-2011, 10:08 PM   #177
cocobolo's Avatar
I put the photo in with the measurement upside down so the folks in Oz could read it...you do believe that, don't you?
Here is where things got out of whack. Between the wall and that 13' mark, the carpet has a real dog leg in the selvedge side. Nice eh?
Old 12-11-2011, 10:10 PM   #178
cocobolo's Avatar
At the start of that bend it's 142" wide, and just a few inches further in it is down to 139 5/8".
Old 12-11-2011, 10:12 PM   #179
cocobolo's Avatar
As a small added bonus there is a hole in the backing...unfortunately, the fibers have thrown a shadow over most of the hole. But it's about 3" long and an inch or so wide.
Old 12-11-2011, 10:16 PM   #180
cocobolo's Avatar
This is a close up of the dog leg. In person it's a real mess. I don't have any idea how this came about, but I will try to find out from Mohawk.
And one more thing, the opposite side of the carpet - which has very obviously been cut - wasn't cut anywhere near straight.
From where the carpet starts off at the wall out to about 14', the cut tapers just over 3" on the pattern. At least that accounts for 3" of the 7" that is missing on the other two pieces.
What is the correct way to redo stair treads. John/Suz Flooring 5 10-13-2011 08:11 AM
Carpet upstairs with hardwood stairs ... what to do with top stair? jmai14 Flooring 3 09-10-2011 08:57 PM
2x12 redwood stair treads cracking in center JimmyRrichards Carpentry 4 08-10-2011 10:29 AM
Refacing stair treads Stair newbee Flooring 2 08-10-2010 10:35 PM
New stair treads and flooring rickkeeter Flooring 2 02-24-2010 10:16 PM
