Carpet Seams - Flooring - DIY Chatroom Home Improvement Forum
Old 04-16-2013, 10:51 AM   #1
Rewards Points: 14
carpet seams
i am putting in glue down frieze carpet. I have four seams in it one room has a seam 17 feet long about six inches from a wall two of the other seams are four feet wide spanning a hallway and the last is right in the middle of a door frame... if any of these are just bad placement it won't be a big deal to change them some. How do i make them look good i know i need to use seam sealer on my cut edges... do i need to use it on the factory edge or should i not even use the factory edge and just cut it off a few inches back also i would like to do a stair way with some of this carpet too so any suggestions on that would be much appreciated also
fgunternahrer is offline   Reply With Quote
Old 04-16-2013, 03:01 PM   #2
Floor Installer
sam floor's Avatar
Rewards Points: 154
carpet seams
Don't use the factory edge, they are never straight. Buy a row cutter to cut the seams.
sam floor is offline   Reply With Quote
Couple carpet questions ponch37300 Flooring 8 09-28-2012 03:30 PM
Flooring Under Carpet Mstrenke Flooring 4 06-24-2012 06:54 PM
Carpet Flooding and Replacement airjay81 Flooring 1 05-08-2012 01:00 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
