Carpet Seam At Doorway - Flooring - DIY Chatroom Home Improvement Forum
Old 12-22-2007, 10:48 PM   #1
PJG
I'm Tryin'
Carpet seam at doorway
I am installing new carpet in a bedroom and don't know how to make the seam with the existing carpet in the hallway. Do I cut the new carpet close to the hallway carpet ? It will not be very accurate. Also, how do I get the tape to seal ? - the doorway is narrow.
PJG is offline   Reply With Quote
Old 12-29-2007, 06:35 PM   #2
Carpet seam in doorway
If there ie carpet in the bedroom and you are removing cut it at the doorwat leaving 4-6 in of the old carpet.You will need a carpet seaming iron and some seam tape.If the carpet was seamed in the doorway previously turn it up side down and place the hot oron on the back of the tape .Once the tape is hot you can peel the old tape off.Next let cool then fold carpet back and straight edge it where you want the new seam to be.Use a carpet knife or ulility knife with a brand new blade.Overlap the hall carpet over the new carpet.With your knife make several 1 in. cuts through the new carpet.Fold it back and straitedge it along your "trace cuts" .Put seam tape under it and seam it togeather.Be warned that this takes some time to master this skill.
Mimayor is offline   Reply With Quote
Old 12-29-2007, 09:00 PM   #3
Building and plumbing
USP45's Avatar
Rewards Points: 150
I am no carpet expert, nor do I install any, but a friend of mine does and I thought I heard her mention something about the fiber directions too?
USP45 is offline   Reply With Quote
Old 12-30-2007, 12:34 AM   #4
fiber direction
If it were the same kind of carpet ,yes you would want to keep the direction of the nap all going one way.If its different carpets it wont really matter.
Old 12-30-2007, 09:21 AM   #5
Home Improvement Guy
ron schenker's Avatar
To check for the nap direction, just brush the carpet with a swipe of your hand and see which way the fibres stand and lay.
ron schenker is offline   Reply With Quote
Old 12-31-2007, 08:33 PM   #6
PJG
I'm Tryin'
Thanks for the info
It sounds like I should not try it the first time on the carpet I want to install.
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 08:26 PM
Carpet Nightmare The Nomad Remodeling 3 09-30-2007 08:25 PM
Carpet - different colours in 2 rooms tonyt Flooring 1 09-09-2007 04:21 PM
glued down carpet...can I cheat? Dusty Flooring 3 10-10-2006 05:18 PM
