Carpet Removal - Flooring - DIY Chatroom Home Improvement Forum
Old 04-24-2014, 09:41 AM   #1
Rewards Points: 83
Carpet removal
I'm pulling up old carpet in my bedroom but I didn't want to remove the baseboards. I'm replacing it with stained concrete flooring that I was just going to add quarter to. I read online to remove the baseboards...is this necessary?
ttwin is offline   Reply With Quote
Old 04-24-2014, 12:36 PM   #2
Rewards Points: 144
It sure makes it easier if the tack strip is under the base.I've seen it both ways but under either condition it would make it easier for the new finish to be applied.
mako1 is offline   Reply With Quote
Old 04-24-2014, 12:46 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
What are planning on doing with the holes in the floor from the tack strip?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 04-24-2014, 12:59 PM   #4
Rewards Points: 83
I'm going to use a self leveling cement
Old 04-24-2014, 01:47 PM   #5
Rewards Points: 12
Don't know if that will look good stained or if stain will stick to it.
The Following User Says Thank You to rusty baker For This Useful Post:
MTN REMODEL LLC (04-24-2014)
Old 04-24-2014, 04:35 PM   #6
Rewards Points: 83
I was hoping I could protect the board with Kraft paper and painters tape
Old 04-24-2014, 04:42 PM   #7
Rewards Points: 12
I mean staining the floor leveler.
Old 04-24-2014, 04:51 PM   #8
Rewards Points: 12,818
Going to have a mess on your hands trying to do that, and end up with a hard cold floor to walk on.
Stain is not paint, it's not going to cover up any of the flaws or repairs.
Just going to make them stick out more.
Old 05-09-2014, 03:04 PM   #9
So just to be clear you want a stained concrete floor in a bedroom?
The baseboard is probably necessary to remove not only so you can properly pour the concrete but also so you can have nice neat edges and base boards when you are done. Leaving them on just sounds like a mess waiting to happen.
Besides with everything that you are going to be doing, removing the baseboards is very simple and quick.
lynathome is offline   Reply With Quote
Old 05-10-2014, 09:51 PM   #10
To get a professional finish the baseboards should be removed.
MandyWoodson is offline   Reply With Quote
Carpet odor removal baking soda allphaser General DIY Discussions 1 12-03-2012 06:51 PM
Staining after vinyl and carpet removal Duration Flooring 0 08-03-2011 03:41 PM
Basement carpet removal hellothere123 General DIY Discussions 1 11-02-2009 09:39 PM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 08:06 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
