Carpet Questions - Flooring - DIY Chatroom Home Improvement Forum
Old 06-26-2010, 05:01 AM   #1
Rewards Points: 342
Question
Carpet Questions
I am looking at some new carbet for my downstairs den. The den is on a slab above ground. The den is reasonably high traffic. I was at this store that had a sale on carpet. And was looking at some inexpensive berber (I don't want to spend a bundle because I could tear everything up in a couple of years. I liked this berber because it had a nice soft feel. The salesman immediately steered me toward a berber that was twice as expensive and said the harder it is the more long lasting. Then I immediately left.
First, what is the going rate for padding, what is the bare minimum that I should be looking for as far as quality in carpet if I want something for a couple of years maybe a little more. How can I tell if I am really looking at cheap or worthless carpet?
tripower is offline   Reply With Quote
Old 06-26-2010, 08:31 AM   #2
ccarlisle's Avatar
Here's a couple of things to bear in mind for your situation:
You say 'downstairs den over slab above ground'; that says to me that the moisture level at the floor level will be higher than normal inside your house. Therefore, wool and cotton carpets are out - as are orientals. Natural fibres would rot. You are left with synthetic, man-made fibres like nylon or olefin.
Then you say 'high traffic'; an olefin will show traffic lanes much sooner than a nylon would, so I would knock out olefin. That leaves nylon. High traffic is best suited to a high density nylon, something that would by definition spring back to its original shape no matter what the traffic load.
You saw two 'berbers'. Berber is a type of weave, not a fibre. So you can get olefin berbers as you can get nylon berbers. Berbers are made in loops, with a natural built-in springiness to them that looks good and shrugs off traffic wear, but not for long; also hides dirt.
So, a nylon berber is one choice. Or a simple nylon, tufted carpet of high quality.
But no matter what you end up taking, keeping it vacuumed regularly and professionally cleaned every 18 months or so is the singlemost best thing you can do to prolong it's life.
Count about 15 years before it needs a change.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 06-26-2010, 09:39 AM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 142
Carpet pad prices vary widely depending on where you live. I would suggest a 7/16 8 lb.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 06-26-2010, 10:44 AM   #4
Rewards Points: 342
Exclamation
Well they were talking to me about $.50 a sq. foot, and that is padding without an moisture barrier.
Old 06-26-2010, 10:45 AM   #5
Rewards Points: 342
Exclamation
Thanks for all of the great info. Yeah, I was looking at nylon already and I don't think moisture is of great concern because there is thin tile underneath the carpet.
Getting new carpet, questions about pad and style MGB_ Flooring 4 01-27-2010 04:37 PM
bubble under carpet after water spill - fixing psittacus Flooring 4 03-06-2009 01:23 AM
Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr chetsy Off Topic 9 12-03-2008 06:41 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
