Carpet/Padding Question? Which Is More Important? - Flooring - DIY Chatroom Home Improvement Forum
Old 12-16-2009, 07:44 AM   #1
Home Remodeler Wannabe
Scotsman's Avatar
Carpet/Padding Question? Which is more important?
Good Morning,
I have been told, that you can buy cheaper carpeting, (NOT total trash) but say I could step down 1 grade up carpet and upgrade the padding and have the same feeling? Is this true or just wishful thinking?
Scotsman is offline   Reply With Quote
Old 12-16-2009, 07:56 AM   #2
Remodeling Contractor
Same feeling but not the same wearability. The cheaper carpet will deteriorate faster.
Old 12-16-2009, 08:08 AM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 126
It's a wash. If you put cheap pad under a carpet, it not only will flatten out before the carpet is worn out, it will also cause the carpet to wear out sooner. The biggest thing with any carpet is to vacuum 2-3 times a week. Keep it clean and it will last longer. I have seen cheap carpet last for years because it was maintained. I have seen expensive carpet ruined within a year. If it starts to get a wrinkle, don't wait, get it restetched. And don't automatically blame the installer. There are some carpet backings that will not hold a stretch.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 12-16-2009, 09:13 AM   #4
I call BS.
My wife picked out the thickest, nicest carpet, and we put down a premium pad underneath. There's no comparison.
A good pad under a midling carpet is better than a cheap pad under the same carpet, but a nicer carpet is a nicer carpet, and you will notice the difference.
Especially if you walk barefoot on it
pyper is offline   Reply With Quote
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Very important water heater question about pressure valve!?! utilitylocator Plumbing 9 02-05-2009 05:18 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
