Carpet Padding For Basement - Flooring - DIY Chatroom Home Improvement Forum
Old 10-06-2006, 07:35 AM   #1
Carpet Padding for Basement
I will be ordering pad and carpet in my basement in the next couple days... When shopping, I have been told to be sure to get a pad with a moisture barrier, and then I was told not to get one with a moisture barrier.
The reasons for a moisture barrier:
1) To protect the pad from any moisture from the concrete.
2) To protect the pad from spills on the carpet.
3) To protect the pad when the carpet is steam cleaned.
The reason why not to get a pad with a moisture barrier:
1) The moisture will be traped between the cncrete floor and pad, and between the pad and the carpet.
I appreciate any advice!
Kyle is offline   Reply With Quote
Old 10-14-2006, 12:23 AM   #2
Floorwizard's Avatar
unless the concrete is COMPLETELY sealed, moisture will find a way thru.
get a low absorption rate pad like a rubber slab.pad and you will get the best in the biz.
Floorwizard is offline   Reply With Quote
Old 10-14-2006, 08:05 AM   #3
Thanks for the info! I will be getting the carpet installed next week...
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 08:26 PM
Carpet Nightmare The Nomad Remodeling 3 09-30-2007 08:25 PM
Stripping rubber padding off a parquet floor nubee Flooring 1 04-22-2007 01:08 PM
glued down carpet...can I cheat? Dusty Flooring 3 10-10-2006 05:18 PM
