Carpet Pad Question: Acoustical Considerations - Flooring - DIY Chatroom Home Improvement Forum
Old 05-05-2013, 08:22 PM   #1
Question
Carpet Pad Question: Acoustical considerations
All,
I am in the planning phase of a project to finish a 1900 square foot basement (see attachment). After much deliberation, I have decided to carpet all but the bar, under the pool table and bathroom. A significant amount of space is dedicated to an open layout home theater. From a standpoint of carpet and pad, what should I use for the best acoustical results?
Thanks!!!
~HT4ME
Carpet Pad Question: Acoustical considerations-full-blueprint-key-furniture.jpg
HT4Me is offline   Reply With Quote
Old 05-05-2013, 08:45 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
It's pretty simple...the thicker, the better. But also understand that how your walls are shaped and made also has an impact on noise..
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
HT4Me (05-05-2013)
Old 05-06-2013, 03:47 PM   #3
Rewards Points: 131
I honestly dont think your choice in carpet/pad is going to make any difference, in terms of what type and how thick, since it's laid on a concrete slab. Thicker carpet/pad will make a difference to your bare footsies while walking on it tho, in addition to you possibly needing longer spikes if using floorstanding speakers ( assuming that, and you currently use spikes for them ).
The layout of the room, how many "dead spots" you have, inside corners, uncarpeted areas, etc., all will much more of an impact on sound than carpet/pad styles, and there will be a lot of options to remedy any issues surrounding them - e.g. wall coverings, acoustic tiles, those free standing sound thingys you place in a corner, etc. etc.
For more thoughts and advice, you may want to search and/or register with AVSforum.com and pose the same question.
Chokingdogs is offline   Reply With Quote
Old 05-06-2013, 04:19 PM   #4
Floor Installer
sam floor's Avatar
Rewards Points: 154
That may help with noise, but any pad over 1/2" thick can cause carpet wear problems.
sam floor is offline   Reply With Quote
Old 05-06-2013, 05:53 PM   #5
Hello sam floor,
If that is the case, what is the best underlay to use from the standpoint of material? Rubber? Foam?
Thanks!
Old 05-06-2013, 05:58 PM   #6
Floor Installer
sam floor's Avatar
Rewards Points: 154
Foam with at least 8lb density.
Old 05-06-2013, 08:29 PM   #7
Sam Floor,
I will difinately follow your recommendation. 1/2" foam underlay with 8 lbs density or higher. Got it! I appreciate the tip. You just saved my carpet!
Thanks,
HT4ME
Carpet Question - PLEASE HELP! davis279 Flooring 1 03-08-2012 10:46 AM
Finding Joists Under Carpet Question dajonx Flooring 11 02-01-2012 12:23 AM
Wet carpet on basement floor wvphysics Flooring 2 12-05-2010 01:26 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 08:26 PM
Wiring Design Considerations Question tjandt Electrical 6 09-26-2006 05:44 AM
