Carpet Pad - Flooring - DIY Chatroom Home Improvement Forum
Old 02-21-2008, 11:32 PM   #1
Carpet Pad
I'm sure that this has been covered, but I got so many hits the search wasn't helpful.
We're looking at carpet, and everyone told us to be sure to get a "good" pad - that you can skimp on the carpet a little , but get a good pad.
Then today the owner of a store, who seemed to know a lot more than salespeople in other stores, told us that that used to be somewhat true but didn't make any sense.
What's the story on carpet pad?
Thanks,
potomac101
Potomac101 is offline   Reply With Quote
Old 02-22-2008, 12:25 AM   #2
I'm a installer for carpet, The store owner is full of it. pad comes im, MM and LBS, like the best pad is say 14lbs 10mm, the ************ty pad is 4lbs 6mm.
thas how that work. the owner will make more $$$ off the carpet sale then the pad sale.
for your house, room. say you need 12x12=144 sqft, div-9 = 16 yrds, thats 1/4 of a bag of pad. say the cost is $ 30.00 for pad.
12x12 carpet 60 oz, Now the owner love's you.
GOOD PAD USED CARPET......LOL
xkempx is offline   Reply With Quote
Old 02-22-2008, 12:27 AM   #3
Old 02-22-2008, 06:56 AM   #4
Guest
Guest
Posts: n/a
Both carpet and pad quality are important. We use a minimum of 7/16" 6LB pad, and commonly sell 1/2" 8LB. We've even done some 10lb on higher end jobs. Anything higher than that really gets to be overkill but it doesn't hurt to have better if you are willing to put the money into it.
It is true that a good pad will prolong the life of the carpet.
Old 02-23-2008, 06:28 PM   #5
We're going with the 8 lb pad and a medium grade carpet for an extremely low traffic area. The installers come Wednesday - is there anything that I should be doing before they come?
I'll make sure that all the nails are tapped down and then I'll vacuum really well. Anything else?
Thanks,
potomac101
Old 02-24-2008, 06:27 PM   #6
Floorwizard's Avatar
get out of their way
Floorwizard is offline   Reply With Quote
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 09:26 PM
Carpet Nightmare The Nomad Remodeling 3 09-30-2007 09:25 PM
Carpet - different colours in 2 rooms tonyt Flooring 1 09-09-2007 05:21 PM
glued down carpet...can I cheat? Dusty Flooring 3 10-10-2006 06:18 PM
