I am undertaking a project this weekend to prepare my basement for a carpet install. My wife has been planning this for years, and now has ordered and paid for the carpet. Installers will be here this coming week. I have some questions about the best way to do some things. The house was built in the 1930s, and has a concrete floor slab of probably less than the ideal 4". Additionally, the previous owners installed drain tiles at the perimeter, as well as VCT directly on the slab. The adhesive is black cutback, and the 12x12 VCT is an armstrong product (found a box with unused tiles in a closet) that I am unsure about the presence of asbestos. From what I have read here, the black cutback adhesive likely has a small amount of asbestos. I know it is fine if left alone.
But there is the problem. While the basement is dry (lived here 3 years without any groundwater problems), we do have some sizeable waves in the floor from previous pipe leaks, etc. All water came from the inside. So I need to replace the wavy tiles, and have enough extras to do it, but I am concerned about disturbing possible asbestos VCT. I had planned to just cut out the bad tiles and lay replacements in place - or maybe just cut along the ridge of the waves and remove the just the warped areas of the tiles . . . not sure what to do.
Now I am also questioning the placement of carpet over this material. Is this OK? My wife wants to use this area as a play room for our kids. The whole thing makes me a little nervous.
Second problem is the method of carpet install. The carpet seller said his guys (they sub-out all the install work I believe) will glue tack strips directly to the VCT. I questioned this method - it seems like the tile would easily break away when the carpet is stretched - but he was sure it would be fine. I don't believe him, even though the work is guaranteed. I'd like to use some kind of fastener for the tack strips, but I'm also concerned that the slab could be just 2-3" thick, and I'd just crack the concrete. Then there is the retro drain tiles too . . . I could use a high-strength adhesive (I saw PL400 and Chemrex recommended in other posts here), but I am pretty sure this would require me to remove a 2" strip of VCT and the cutback all around the perimeter of the carpet install.
SO I'm not sure the best way to go on this one, and I'm hoping some of you experienced flooring guys can lend me some advice. I am leaning toward trying to find a fastener that will work through the tack strip, VCT, & cutback, and penetrate the slab no more than 1-2". Is there such a thing? Or is there another simple way for me to get this done in just a couple days? Thanks in advance for any suggestions.
