Carpet Over Hardwood Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 06-02-2009, 12:20 PM   #1
Carpet over hardwood floors
I have beautiful oak hardwood floors with carpeting installed over them.
I want professional carpet cleaning done. Deep hot water extraction as I understand it.
There is carpet pad under the carpet. I am told the floors will not be damaged because the pad does not get wet. I am skeptical.
Does anyone have experience with this?
Appreciate your advice.
sailprice is offline   Reply With Quote
Old 06-02-2009, 01:01 PM   #2
Remodeling Contractor
If you are using a professional cleaner with adequate equipment you will not have any problems. With a DIY rental machine you will not only not clean the carpet but ruin the padding and the floors.
Old 06-03-2009, 12:25 PM   #3
Good advice
Sounds like very good advice.
I am contemplating Stanley Steemer which has a good reputation locally. I assume their equipment is adequate.
What is adequate equipment?
Old 06-03-2009, 12:46 PM   #4
Theirs are fine. The issue is that low end rental equipment is not powerful enough to remove most all of the water while cleaning, leaving the carpets too wet. They should only be damp when they are done. Nothing with wood feet should be placed back on the carpet for at least 24 hours. These will stain the carpet.
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
Removing carpet pad and paint from hardwood floors Rahci Flooring 10 05-14-2008 02:54 PM
Want to try to refinish hardwood floors and parquet floors proofer Flooring 11 04-20-2008 06:59 PM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 08:06 AM
