Carpet Over Cement - Flooring - DIY Chatroom Home Improvement Forum
Old 10-10-2011, 11:50 AM   #1
Carpet over cement
I want to carpet my back room, which has a cement slab floor. The floor is raised about 2 feet from outside grade on a concrete foundation. Do I need to put any underlayment down besides the carpet padding before carpeting over it?
OffToAShakyStar is offline   Reply With Quote
Old 10-10-2011, 11:52 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Carpet over cement
Shouldn't.
XXX
Old 10-10-2011, 12:04 PM   #3
Originally Posted by Bud Cline View Post
Shouldn't.
Thanks. I had been told by some people the cement would wick moisture and cause mold. But it was my understanding that would only be a concern if the pad itself was touching earth.
Old 10-10-2011, 12:08 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Moisture can be an issue and it must be allowed to evaporate. If there is a crawl space down below the base should be covered with plastic maybe, and the walls vented in a couple of places to allow for cross-ventilation.
The truth is...carpet is installed over concrete all of the time without any consideration being given to moisture migration from the slab. Sometimes there are issues, sometimes there are not.
XXX
Old 10-10-2011, 12:10 PM   #5
How would one vent a wall properly?
Old 10-12-2011, 12:38 AM   #6
Carpet over concrete
Before you install the carpet, do a mat test. Just tape down a one foot square piece of 6 mil poly with duct tape and leave it taped on all four sides for 48 hours. Pull it up and check to see if there's any moisture on the poly or if the concrete is darkened where the poly film was. If it si, you may need to seal your concrete first before installing pad and carpet.
Distributor Rep is offline   Reply With Quote
Old 10-12-2011, 08:17 AM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Distributor Rep:
"Before you install the carpet, do a mat test. Just tape down a one foot square piece of 6 mil poly with duct tape and leave it taped on all four sides for 48 hours. Pull it up and check to see if there's any moisture on the poly or if the concrete is darkened where the poly film was. If it si, you may need to seal your concrete first before installing pad and carpet."
You are young and very new at this aren't you - DUDE?
Old 10-12-2011, 09:07 AM   #8
Haha.
Having a little fun with ya, Bud.
remove outdoor carpet from cement Nancy Pace Remodeling 9 04-26-2011 08:35 AM
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 10:41 AM
Glueing Carpet to Cement Blocks dronefly Flooring 1 04-04-2010 02:26 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
