Carpet To Laminate Transition - Flooring - DIY Chatroom Home Improvement Forum
Old 11-07-2010, 01:49 AM   #1
carpet to laminate transition
What is the best way to transition existing carpet to new laminate so the carpet will both stay where it is and fit underneath the T-moulding? We cut out a large section of carpet in our dinette area which is part of our great-room and will lay laminate down. My first thought and attempt was to cut the carpet and padding, cut the padding back another 2-3 inches underneath the carpet, put re-used tack strips down and stretch/push down the carpet on to the tack strip. Do I need to fold the carpet first before attaching to the tack strip so the tacks don't push through the carpet? When I do that it doesn't look like the T-moulding would fit over the carpet.
8roty is offline   Reply With Quote
Old 11-07-2010, 10:45 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 52
Put the molding track close to the laminate. Put the tackstrip within approx 3/8" of the track. Stretch and trim the carpet. Put the T molding over the top of both edges.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 11-08-2010, 02:40 AM   #3
T mold doesn't work well as a carpet end cover . The reason is the part of the tmold that covers the carpet is very thin , The carpet is not a solid surface that will support this , END MOLD is what is used and the carpet is tacked and stretched tight to the end molding ,not under it . It is possible to use the end mold , But not recomended
tacomahardwoodfloors.com
tacomahardwood. is offline   Reply With Quote
Old 11-08-2010, 07:41 AM   #4
Rewards Points: 52
CRI installation standards prohibit tacking carpet in doorways. It would void any warranty. Besides a plush carpet looks terrible when tacked.
Anyone know how carpet is supposed to meet the laminate transition? Player Flooring 7 07-20-2010 04:09 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Laminate to Carpet Transition Dallas Flooring 3 12-21-2008 07:32 PM
put carpet on laminate > dainova Flooring 3 06-15-2008 08:49 PM
Mixing Hardwood, Carpet, and Laminate! reptilicus81 Flooring 3 11-25-2006 09:43 PM
