Carpet/laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 02-22-2011, 08:34 PM   #1
Carpet/laminate flooring
I have a carpet that ends on one side with an "S" curve ( 12 feet) This end abutts with Allure plank flooring for the Kitchen. Is there any kind of flexible edge moulding that is available to blend the two.?
Eilyne is offline   Reply With Quote
Old 02-26-2011, 07:58 AM   #2
Pro Newbie, Thank You!
There are rubber transitions available in different colors that can be used for applications such as this, but they are used mainly in commercial buildings. I don't believe they would look good in a residential home.
Is the carpet glued down, or stretched in over pad? If stretched in, the tackstrip can be removed and replaced with flexible "beat-down" metal transitions, also known as carpet gripper. They come mainly in the colors silver and gold. Of course, the carpet will need to be stretched back up to the gripper metal and tucked inside it. Hope this helped.
Also, do not nail the transition directly to the laminate.
Broadhurst is offline   Reply With Quote
Transition of Hardwood Flooring on Stairs rkirby Flooring 1 02-02-2011 07:06 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 10:00 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 12:32 PM
