Carpet To Laminate Floor Transition - Flooring - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 05:42 PM   #1
Rewards Points: 150
Carpet to Laminate Floor Transition
Our house was broken into and the carpet is trashed. We will be installing laminate flooring in it's place. The carpet being replaced is in our living room and it extends into our master bedroom. The laminate will stop at the entrance to our bedroom and the bedroom will remain carpeted. I know I will need to add an endcap for the transition from laminate to carpet but how far back do I need to cut the carpet at the door? What do I need to do to keep the carpet secured at the door? Will I need to staple or add a tack strip?
Picture is attached for reference. This is looking from the living room hallway into the master bedroom.
Thanks!
Jason
stradt03 is offline   Reply With Quote
Old 01-04-2012, 05:47 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Transitions take place under the center of the door.
We'll let a carpet installer make more suggestions.
XXX
Old 01-04-2012, 06:12 PM   #3
Rewards Points: 150
thanks Bud. I'll wait for a carpet installer's response!
Old 01-05-2012, 08:19 PM   #4
Rewards Points: 150
come on in carpet guys!!
Old 01-05-2012, 09:04 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 112
Put the transition track right under the door. Put a piece of tackstrip about 3/8" back from the track. Kick the carpet up, rub it down, trim and tuck in. Finish the laminate leaving a gap. Put the transition cap on and you are done. The cap will cover both edges and with the door closed you will only see whatever is on the floor of the room you are in.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-05-2012, 09:06 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Rusty's bus was late. Sorry for the delay.
XXX
Old 01-05-2012, 09:11 PM   #7
Rewards Points: 582
iwuold put it under center of door then when your in one room or the other you only see whats on that floor...
Old 01-05-2012, 09:12 PM   #8
Rewards Points: 13,694
Also consider engineered flooring instead.
Real wood, can be refinished, long lasting finish. does not look plastic like laminite, does not feel bouncy, not that much more expencive.
I can just walk into a house with laminite and know what it is, not so with engineered, it looks and is real wood just more stable.
carpet to laminate transition 8roty Flooring 3 11-08-2010 06:41 AM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 01:20 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
put carpet on laminate > dainova Flooring 3 06-15-2008 07:49 PM
Mixing Hardwood, Carpet, and Laminate! reptilicus81 Flooring 3 11-25-2006 08:43 PM
