Carpet Installed On Stair--coming Loose--- - Flooring - DIY Chatroom Home Improvement Forum
Old 11-27-2011, 07:38 AM   #1
Carpet installed on stair--coming loose---
My contractor installed the carpet on my basement stairs but it looks as if he didn't use a tackless strip. Or if he did carpet is not kicked in to grab it. I want to call him on it, he's been doing some shoddy work lately.
Do you have to use tackless strip on stairs or can you use glue? Shouldn't he of asked my preference?
If carpet not attched to tackless strip will it eventually loosen from stairs, it looks like it's loosing now.
How would it be fixed?
Trying is offline   Reply With Quote
Old 11-27-2011, 08:39 AM   #2
DIY staff
Rewards Points: 7,174
Welcome,Trying---
I moved this and made it a new thread----your question is unique and needs its own place---Mike---
Old 11-27-2011, 10:31 AM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 58
If it has pad under it, it needs tack strip. If not, it can be glued. Some installers just staple carpet over pad. That is not acceptable and won't last. It violates CRI installation standards.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
Trying (11-27-2011)
Old 11-27-2011, 11:03 AM   #4
Rewards Points: 272
Have to agree 100% with Rusty. It is easy enough to find out how it was done, just have the installer remove the carpet from the bottom step to show you how he installed it.
fixrite is offline   Reply With Quote
The Following User Says Thank You to fixrite For This Useful Post:
Trying (11-27-2011)
Carpet upstairs with hardwood stairs ... what to do with top stair? jmai14 Flooring 3 09-10-2011 09:57 PM
Butting new floor carpet to temporary old stair carpet gordongroom Flooring 1 03-23-2011 05:04 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 09:26 PM
glued down carpet...can I cheat? Dusty Flooring 3 10-10-2006 06:18 PM
