Carpet Installation - Flooring - DIY Chatroom Home Improvement Forum
Old 05-06-2008, 09:09 AM   #1
Carpet Installation
I just had berber carpet installed and there is a gap between the base and the carpet in some spots. The base is straight and level and no gap was present with the previous carpet. I was wondering if this happens and i just need to install new base or if i should have the company come out and fix it.
Greg
GS33 is offline   Reply With Quote
Old 05-06-2008, 09:40 AM   #2
sestivers's Avatar
Rewards Points: 107
That's relatively normal, although I think the installers should remind the customer that happens when quoting a job. Your new carpet just doesn't have as much pile height as your old carpet did. The same thing happens when you install laminate flooring where there used to be carpet. I doubt that the installers are going to do anything. You have a couple options:
Cheapest: Remove the baseboard from the wall, paint the wall where the baseboard was covering it (at least the top 1/2" or so), and re-install the baseboard at the proper height. If you don't have leftover paint, get a quart color matched. This option costs only time.
Most typical: Install quarter-round trim at the base of your baseboard. Some prefer the look of this option, but it costs more for materials, and you have to cut a bunch of trim.
There are probably other ideas too.
Steve
sestivers is offline   Reply With Quote
Old 05-10-2008, 09:48 AM   #3
Floorwizard's Avatar
great advice.
I agree.
Floorwizard is offline   Reply With Quote
Carpet installation on Dricore Cyrus Flooring 8 03-24-2008 09:14 AM
Remove baseboards before carpet installation? digexpressions Flooring 6 12-17-2007 09:46 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 08:26 PM
