Carpet Install Expert Advice Needed - Flooring - DIY Chatroom Home Improvement Forum
Old 05-09-2012, 11:57 AM   #1
Rewards Points: 14
Carpet Install expert advice needed
Thought I was being cute installing carpet in my whole house (alone). Big job, but glad I did it.
My only problem is with one major seam. It's 5 ft long between 2 rooms having the same carpet. It was my first seam and I did it completely wrong. Namely running the carpet iron backwards, thus getting nap between bottom of the carpet and the tape. I realized what I had done and took the seam apart and redid. Looked a lot better but not perfect like my latter seams are. So I took apart again and by doing this wrecked the edges so bad that stretching still wont give me enough material to get clean straight edges to join.
Question is what to do???
My thought is to take up one of the rooms and shift the carpet 3/4 in or so to give me material to get the clean straight edge I need. I can lose the 3/4 in on the other side as it's tucked under a heater and won't show.
or
Would it be better to make a roughly 5 in wide patch and put it between the doorway edges thus making 2 seams.
Hope someone can give me good advice. Thanks
Cruisinfanatic is offline   Reply With Quote
Old 05-09-2012, 07:50 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 114
Better to shift it than make a "saddle" seam.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
Cruisinfanatic (05-10-2012)
Old 05-09-2012, 08:49 PM   #3
Pro
JetSwet's Avatar
Rewards Points: 502
Rusty, do you have to make shore the carpet nap is running the same way when you are seaming them together?
JetSwet is offline   Reply With Quote
Old 05-09-2012, 09:13 PM   #4
Rewards Points: 114
Sure do. ....
Old 05-10-2012, 01:20 PM   #5
Rewards Points: 14
I will do that, thanks
Old 05-10-2012, 04:10 PM   #6
I agree with the other person who replied. Make sure that you are running the carpet the same way and that the nap lays the same way.
RhodesHardwood is offline   Reply With Quote
The Following User Says Thank You to RhodesHardwood For This Useful Post:
JetSwet (05-10-2012)
Chain link fence install advice ponch37300 Landscaping & Lawn Care 1 11-10-2010 06:08 PM
wet carpet in basement, need advice Practcing Flooring 18 09-24-2010 09:11 AM
Interior door install, Carpet?? philly529 Carpentry 3 03-10-2010 10:22 AM
no ductwork needed to install a wall fan ? amakarevic Plumbing 2 01-22-2010 05:23 PM
Can I Install Carpet on Stairs as a DYIer?!? Rhat Flooring 5 09-26-2009 01:42 PM
