Carpet Install & Basement Wet Bar - Flooring - DIY Chatroom Home Improvement Forum
Old 11-11-2012, 01:59 PM   #1
Carpet install & basement wet bar
As part of finishing the basement we are doing a wet bar in the basement rec room. I know the cabinets should go in before the carpet of the rec room, but that is not possible for me right now. So, what should I have the carpet installers do? I can think of two things:
1) Put plywood down that is cabinet depth and have the installers go ahead and put tack strip along the plywood and install up to it.
2) Have the installers put the carpet in as if the wet bar would not be there and cut the carpet out (and tack strip) when I install the cabinets. This would mean I have someone come in and redo the tack strip and stretch the carpet back in.
Right now I am leaning toward option 2. What do you guys think? Any other ideas that might be better?
Coach4094 is offline   Reply With Quote
Carpet Install expert advice needed Cruisinfanatic Flooring 5 05-10-2012 04:10 PM
Tile and carpet on concrete basement floor LMPD Flooring 1 02-09-2012 10:00 AM
Carpet cleaning - sump water n0c7 Flooring 17 08-29-2011 07:04 AM
Finishing Basement, carpet install order? tigerbalm2424 Flooring 33 07-24-2008 08:35 AM
How Do I Install New Duct Lines For My Finished Basement? luweee HVAC 17 01-12-2008 03:01 PM
