Carpet To Hardwood Transition. - Flooring - DIY Chatroom Home Improvement Forum
Old 02-23-2011, 03:29 PM   #1
Carpet to hardwood transition.
I'm re-doing some flooring that was damaged in a leak, and will end up with some carpet (existing) and some hardwood. From the reading I've done it seems like there are two choices to finish the carpet at the transition:
1. Use a tackless strip.
2. Fold and staple the carpet (no tackless strip).
What are the pros and cons of these approaches?
We had a couple of transitions that used tackless strips and I didn't think they were particularly good, but maybe that was the installer. I quite like the idea of the fold and staple but it would likely require me to purchase a stapler for this one job.
Kiwi. is offline   Reply With Quote
Old 02-23-2011, 03:55 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 126
Folding and stapling doesn't usually look very good. There will be dimples wherever it is stapled.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 02-23-2011, 09:56 PM   #3
I'm also into transitioning from carpet to hardwood... However, I'm getting rid of all my carpet lol
One of the bedrooms here was done in laminate. The transition there used a metal tack strip with a rubber top that pressed down into the metal. I've attached a couple pictures of the transitions that I haven't pulled up yet as I'm not that far into the process. Pic #1 goes from carpet to tile and #2 goes from carpet to linoleum. Hope this helps!
Fantastic is offline   Reply With Quote
Old 02-23-2011, 10:11 PM   #4
Rewards Points: 126
I've given up telling people about trac-metal transitions, because most people don't like the way they look. They are the right way and are the only way sanctioned by CRI.(Carpet & Rug Institute). They set carpet installation standards.
carpet to laminate transition 8roty Flooring 3 11-08-2010 06:41 AM
hardwood floor to carpeted step transition DIYguy2000 Carpentry 7 11-06-2009 12:09 PM
Transition between wood and carpet preciouschristy Flooring 1 08-20-2009 01:21 PM
Engineered Hardwood: Inlaid transition? SteveSmith98 Flooring 6 03-24-2009 11:21 AM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 07:06 AM
