Carpet Damage From Cat - Repair Ideas? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-12-2011, 10:23 PM   #1
Question
Well, the faithful furry feline has had his way with the carpet leading to the master bedroom. He was not a fan of having the door closed and began to scratch at the carpet underneath the door and well.... he won.
http://imgur.com/a/ZztoN
Attached is a couple pictures of the area. The carpet is a semi long shag and is started to fray. Does anyone know of a good way to repair the damage? Would cutting it out and putting in a new piece work for a high traffic area? Would a piece of molding covering the damage do the job for now?
Hopefully someone has a good idea before I start hacking at the floor!
Thanks,
Chris
Klutze is offline   Reply With Quote
Old 05-12-2011, 11:23 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
An installer could take a leftover piece or cut a piece out of a closet and repair it. Not that hard to do with the right tools and skills.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 05-12-2011, 11:54 PM   #3
Too Short? Cut it Again!
True enough. An installer can seam a piece to replace that damaged and stretch it back down in place. The problem is going to be getting someone out for such a small job I suspect. Cat going to be right back at it?
Old 05-13-2011, 12:32 AM   #4
No, we've learned to just leave the door open so it should be fine.
I haven't looked too much into hiring someone to repair it. But you raise a good point if someone will be willing to fix such a small area.
Old 05-13-2011, 02:52 PM   #5
is the cat the same color as the carpet?
Old 05-13-2011, 04:27 PM   #6
Rewards Points: 12
Someone should be willing to fix it for a minimum. If they have a Kool Glide, it's an easy fix.
Old 05-13-2011, 10:53 PM   #7
Sounds good, I think I'll call around and see how it goes!
Old 05-14-2011, 01:34 AM   #8
Agreed. Not a complicated repair. You do have carpet that can be taken from the back of closet or scraps saved?
If not, you are going to have to gut and skin the cat and stretch the pelt instead of carpeting. And hope nobody notices the color difference.
Bless you for keeping cats clawed. In the US we still think it cool to declaw. As it should be, it is illegal in most other countries. If you love furniture and drapes so much. Pick a different pet.
Spikezilla was near 25 pounds of orange tabby once I slimmed him down. With a quality nail trimmer from the vet, not a piece of crap spring loaded thing from a box store, I could clamp him between my legs and hearing the choir from the depths of Hell and sensing unhappiness, get him done in a few minutes.
Something you should know? That you may not?
Cats grow claws in two directions. Obviously they grow the claws out but they also grow a layer up. Imagine if you had another layer of nail growing toward your cuticles. You would scratch to get rid of it too? This is why you find those cat claw shells around.
My clawed cats never hurt even very expensive furniture if I kept them trimmed. I gave them things to claw at like tree trunks and things in the kitchen.
Of course, like the OP, I caved and just let them into the bedroom. 25 pounds of cat head butting a bedroom door, over and over, destroys intimacy, I promise.
Old 05-14-2011, 10:38 AM   #9
Rewards Points: 12
Declawing is amputation. They take off the first joint. It's would be like cutiing off the part of your finger where the fingernail grows. Please don't do that to a pet. If you can't handle claws, don't get a cat.
Tags
carpet damage , carpet fray , carpet repair
Hydronic in floor heat with carpet Jacobs.sr22 Flooring 1 01-17-2011 11:31 PM
water damage remove mold & repair or replace drywall homerepair1 Drywall & Plaster 2 02-22-2009 11:00 AM
Flooring for basement with water issues Leoskee Flooring 27 08-27-2008 09:49 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 09:26 PM
glued down carpet...can I cheat? Dusty Flooring 3 10-10-2006 06:18 PM
