Old 01-15-2012, 09:48 PM   #1
Carpet on concrete garage slab
I am turning a ground level garage into living space. It has a concrete slab with a 1 foot still on three sides. The floor isn't exactly perfect (it has approximately a 1 inch variation throughout). I was planning on putting down a 6 mil vapor barrier even though I have never had any water problems in the garage then installing a very thick pad or wool padding then carpet. I have a few questions; 1. Will the floor be too cold considering my heat comes from the ceiling? 2. Will the floor's seem uneven still? 3. How far up the wall where the sill is located do i put the barrier and do i have to seal it or just staple it to the wall sitting on the sill? Am I just being too cheap or do I need to install a subfloor before any other flooring goes down?*Thanks
Truth is offline   Reply With Quote
Old 01-15-2012, 09:55 PM   #2
Pro Flooring Installer
rusty baker's Avatar
I would skip the vapor barrier. It will just promote mold growth. I have installed a few thousand yards of carpet in garage to room conversions with no problems. The carpet will allow the concrete to breathe.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
Truth (01-15-2012)
Old 01-15-2012, 09:57 PM   #3
If the floors not flat then the carpets not going to be.
If you want the floor to be warmer then you'll need to add sleepers and foam insulation in between the joist.
Got a permit for any of this work? The countys going to want to know about it.
Old 01-15-2012, 10:00 PM   #4
Doing all my homework before I invite the inspector back...
Old 01-15-2012, 10:03 PM   #5
What type of padding would you suggest?
Old 01-15-2012, 10:04 PM   #6
There are pads that resist mold and moisture. Ask your dealer what they have.
Old 01-15-2012, 10:07 PM   #7
Thank you, last question...I was told by a friend on the west coast that his garage floor was not level but put down carpeting and it's not noticeable at all with the thick pad. Is that your experience too?
Old 01-15-2012, 10:12 PM   #8
If it's not too uneven, it will be fine.
Truth (01-15-2012)
Cement backer board over kitchen concrete slab gtimk4 Flooring 2 02-19-2012 03:46 PM
Can I use my existing concrete slab for flooring... Somerichs Flooring 4 01-17-2011 12:20 PM
Basement Garage with Concrete Slab: To Vent or not to Vent N-GA-Homeowner Remodeling 3 05-29-2009 07:13 AM
Removing concrete slab on 3rd floor bathroom NowItsShowtime Flooring 2 03-26-2009 03:17 PM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 11:51 PM
