Carpet To Concrete Floor Transition - Flooring - DIY Chatroom Home Improvement Forum
Old 12-13-2011, 09:56 AM   #1
Rewards Points: 79
Carpet to concrete floor transition
We had a water problem due to faulty roof design. During a power outage 5 years ago it caused a small flood in the basement. We had to rip up the carpet at the time and we have now repaired the problem completely and also put in a battery backup sump pump just in case.
We just replaced all the drywall due to mold and are ready to re-carpet the floor. My question is what is the best transition from carpet to concrete going into the utility room where the well water comes in and is treated; the only area where we still have to worry about leaks.
Our plan is to use an oak threshold at the doorway, then caulk the entire perimeter of the utility room where the wall meets the floor. That way if there ever is a small leak, any water would stop at the wall and have to flow into the French drain. It wouldn’t roll out the door under the new carpet.
Some have said I should use a granite threshold. Is that necessary? Does this sound like a reasonable precaution or is it overkill?
papageek is offline   Reply With Quote
Old 12-13-2011, 07:46 PM   #2
DIY staff
Rewards Points: 7,174
Cheap insurance I would call that---A water proof strip of some kind would give you some peace of mind.
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 11:58 AM
getting rid of carpet > concrete floor > polish or stain? johnlvs2run Flooring 24 11-23-2010 10:31 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
remove gleued carpet from concrete floor nkcnf Flooring 6 12-31-2009 12:49 AM
Finishing Basement, carpet install order? tigerbalm2424 Flooring 33 07-24-2008 08:35 AM
