Carpet Coming Loose On The Stairs-how To Fix? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-22-2008, 04:31 PM   #1
Rewards Points: 212
Carpet coming loose on the stairs-how to fix?
I've got carpet coming loose from the stairs. The areas that are loosely fitting are where the carpet should be tucked under the front lip of the step.
To fix, can or could I use a staple gun or will that just pull loose eventually? Or should I use a carpet knee kicker to secure back down? The reason I bought up the staple gun for securing it is because I've never used a knee kicker before but do have easy access to one.
Any ideas?
imola ghost is offline   Reply With Quote
Old 09-22-2008, 07:22 PM   #2
Use A Staple Gun After You Kick It Tight . Thats How They Do It
trademarktile is offline   Reply With Quote
Changing from carpet stairs to wood stairs DIY_user Remodeling 16 07-29-2010 07:16 PM
screws coming loose Baffeled Building & Construction 4 08-13-2008 08:48 AM
loose carpet on stairs econdave Flooring 2 06-15-2008 09:29 AM
Carpet on stairs loose econdave General DIY Discussions 4 04-27-2008 06:23 PM
