Old 01-13-2011, 12:28 PM   #1
Carpet
I am getting ready to purchase new Carpet, and was woundering since my padding is in Great shape, Can I just have the the Carpet installed over it? And I also was looking for a Decent Brand name Carpet, probably with stain Master, I was looking at Lowes, But there is a Catch, you have to have them install, and new padding also. Just trying to get the best bang for the Buck, I am going to purchase real soon, So please help me get the best Carpet. What do you fell is the best brand for the Buck....
splinter2 is offline   Reply With Quote
Old 01-13-2011, 12:37 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Carpet
All carpet mills have good and bad grades. Just make sure it's nylon. Wool is great but really expensive. Polyester is cheaper but tends to ugly out. Don't buy because of wear warranty. Those are based on the length of the yarn and carpet yarn doen;t wear shorter. It loses it's twist and mats. Polyester is the worst at losing it's twist. Most carpet isn't warranteed being installed over the old pad. You can get a better deal from a corner carpet store than a big box.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 01-13-2011, 06:05 PM   #3
woodman58's Avatar
Carpet
There is a place in Georgia that sells to the public. Their # is 1-800-622-7561. Ask for Greg. They will either send you samples or you can look for carpet locally. Once you find the carpet, callthem and get their price. They will need to know the brand name, the style, and the color. Get any and all names and #'s from the back. Most stores private lable their carpets. They may need the store name. When you find the carpet you like they can send you the sample to make sure it is right. I have been dealing with them for 10 years. They will honor the manufacturers warrenty. The only draw back is you will have to have your installer pick the carpet up at the closest truck terminal. They are located in most citys.
woodman58 is offline   Reply With Quote
The Following User Says Thank You to woodman58 For This Useful Post:
Jackofall1 (01-13-2011)
Old 01-13-2011, 06:31 PM   #4
Carpet
By the time you pay the shipping, you won't save much. And most installers charge extra for picking up at a terminal. Make sure you figure all the costs if you go that route.
Old 01-13-2011, 06:51 PM   #5
woodman58's Avatar
Carpet
Even after adding in the shipping charges, their prices are lower than any retail prices I have found. I live in the St. Louis area and the freight Charge is about .75 per yard. I will be worth your while to get a price.
Old 01-15-2011, 10:03 PM   #6
C W
Carpet
Trust Rusty on this as Nylon is absolutely best.As far as warranty a lot of stores will not warranty over existing pad as well as having their own installer install the product. If your underlay is in great shape you can buy carpet and get it intalled yourself and it should come with a manufacturers warranty. Check pad in traffic areas for density. A well bonded chip foam 8-10lbs is in my mind better than most.
C W is offline   Reply With Quote
Wet carpet on basement floor wvphysics Flooring 2 12-05-2010 02:26 PM
bubble under carpet after water spill - fixing psittacus Flooring 4 03-06-2009 02:23 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 09:26 PM
