Carpet - Flooring - DIY Chatroom Home Improvement Forum
Old 04-14-2013, 12:33 PM   #1
carpet
can new carpet be layed over old carpet (40 years old) padding glued down?
byrd is offline   Reply With Quote
Old 04-14-2013, 12:46 PM   #2
Floor Installer
sam floor's Avatar
Rewards Points: 154
You mean the old padding is glued down? Or you want to glue carpet over the old padding?
sam floor is offline   Reply With Quote
Old 04-14-2013, 12:59 PM   #3
old padding is glued to floor
Old 04-14-2013, 01:00 PM   #4
and also stapled, go figure, was done in the 70's
Old 04-14-2013, 02:11 PM   #5
Floor Installer
sam floor's Avatar
Rewards Points: 154
Yes you can stretch in carpet over it. Not the greatest idea tho. Could be you have bubble rubber pad(actually made from clay) as it got old, it got hard and stuck to the floor like concrete. If it isn't real thick, you can staple another layer of pad over the top of it and stretch the carpet in on top.
Old 04-14-2013, 11:39 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
It's sort of like putting on a clean pair of underwear over your current dirty pair......
Yea...you can do it.....but do you really want to?
Couple carpet questions ponch37300 Flooring 8 09-28-2012 02:30 PM
Flooring Under Carpet Mstrenke Flooring 4 06-24-2012 05:54 PM
Carpet Flooding and Replacement airjay81 Flooring 1 05-08-2012 12:00 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
