-   -   Carpentry: PT Plywood subfloor - Putting flooring on it? (http://www.diychatroom.com/f5/carpentry-pt-plywood-subfloor-putting-flooring-74093/)
Jeffries 06-18-2010 07:41 PM
We are getting a sunroom built on our house and the installers have just :(put down a pressure treated wood floor. We have just found out that we can't glue down vinyl flooring over this pressure treated wood. What can we do now, or put over, this p.t. wood so we can lay down vinyl flooring on top of it?
I'd sure appreciate an answer. Thanks, Jeffries
Just Bill 06-19-2010 06:00 AM
Not sure I understand. Framing for any outside structure if often done with PT wood, but the subfloor(plywood, OSB) is not necessarily PT, and will accept most any floor covering. Even if it is PT plywood, an underlayment plywood can be installed to go with the vinyl.
This is a 'DIY' website, not a 'what did my contractor do' website.
Jeffries 06-19-2010 12:53 PM
Just Bill
Thank you for your reply and I do know this is a DIY website. We are installing the flooring ourselves and were wondering if it would adhere to the PT wood.
DangerMouse 06-19-2010 05:31 PM
Yup, just put a thin plywood subfloor down and vinyl away!
DM
JazMan 06-19-2010 09:52 PM
Not so fast.
PT plywood should not be used indoors, I wonder why they did that? I'm not sure if there's any health hazard with the new chemical used in PT, but I do know the moisture content is off the chart. It may be OK to install an underlayment and then vinyl after the PT dries? I wouldn't do it, but you can check with the manufacturer on that. Is this new PT the subfloor or was there a subfloor and this is the underlayment?
OK, now my question. Why vinyl in a sun room? It's not what I'd consider an appropriate flooring in that kind of room.
Jaz
firehawkmph 06-20-2010 04:29 PM
Also one other thought, if you find out it's ok to put some kind of underlayment over the PT plywood, make sure you use fasteners that are approved for contact with PT wood. Usually means hot dipped galvanized or epoxy coated like the newer deck screws. The boxes are starting to say 'safe for use with AQ', that's the new treatment in PT wood.
Mike Hawkins:)
Jeffries 06-21-2010 09:47 PM
Mike Hawkins:)
Thanks so much for the info on the right screws to use. That's what we'll do. :thumbsup: Jeffries
Jeffries 06-21-2010 10:02 PM
Carpentry
Originally Posted by JazMan (Post 458753)
Not so fast.
Jaz
Jaz, we are putting a plywood subfloor over this P.T. wood floor. We are also wondering why P.T. wood was used. I wasn't sure what kind of flooring to put over the subfloor and thought vinyl would be OK. If that's not considered appropriate what would you suggest?
Jeffries
