#1 |
Can't get cement boards level
I'm installing tile floors for the first time. My subfloor is level, but as I lay my hardibacker I can't get the seams to level. They are perfect until I start to screw down the boards, then they shift up and down at random. Most of them are barely off, but one is almost 1/4" off. I'm assuming that's a big problem.
Before I lay tile, how can I make the boards level again at the seams? |
#2 |
Super Moderator
What are you using for tile backer? Are you bedding it in thinset?
New members: Adding your location to your profile helps in many ways.--M-- |
#3 | |
Tileguy
Can't get cement boards levelQuote:
What specific board. which screws or nails, thinset? Thinset under the board, what size trowel, are you fastening from center out or diagonally? Jaz
Tile 4 You LLC Troy, MI KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME! |
#4 |
Hardibacker 1/2" board....thinset under the board with 1/4" notched trowel, hardibacker 1 5/8" screws...center out
#5 |
So far I've laid 5 boards and only one seam of one of them is significantly out of level. Could I use patch and leveler to make it less dramatic?
#6 | |
Tileguy
Either the floor was not flat to start, or you created the hump while installing the boards. I bet the board lifted as you were driving the screws which can easily happen with Hardie. Is the problem along an entire seam or just near a screw? Jaz
#7 | |
Each board rose slightly as I was installing screws, but fell back to level as I tightened. This one seam refuses to go back down. I removed the screws and installed them again about an inch away from each original hole and that didn't solve the problem. |
#8 | |
Tileguy
Jaz
#9 |
If you predrill the holes with a masonery drill that will not happen.
| Display Modes | |
| a few quick questions about shower cement board and hydro ban | diy'er on LI | Tiling, ceramics, marble | 2 | 04-27-2012 11:16 PM |
| How to repair a concrete floor we just had repaired! | timbo59 | Flooring | 11 | 01-04-2012 07:15 PM |
| Tub Flange and level tiling | DIY Girl | Kitchen & Bath Remodeling | 2 | 09-14-2011 08:58 AM |
| cement board on top of cement brim in washroom | avi | Remodeling | 9 | 09-08-2011 08:05 PM |
| how to level an incredibly uneven cement basement? | rbes | Flooring | 6 | 09-09-2008 05:32 PM |
