Cannot Seem To Get Wood Floor Corner Sanded - Flooring - DIY Chatroom Home Improvement Forum
Old 03-06-2012, 03:11 PM   #1
Cannot seem to get wood floor corner sanded
I now own a belt sander, orbital sander, and a palm sander, each of which now have 40 grit sand paper which barely cut through the layer of varnish on my foyer's wood floor. I was able to get through most of the varnish, but I sat with the palm sander in the corners for 30 minutes and did not get much accomplished. Any suggestions?
Image of corner
Edit: I should add that the stuff that is on the floor (varnish I think) is gumming up the discs/belts of everything I put down, even without putting any pressure on the sander.
somecallmemike is offline   Reply With Quote
Old 03-06-2012, 09:01 PM   #2
Rewards Points: 152
How about an oscillating tool?
burnt03 is offline   Reply With Quote
Old 03-06-2012, 09:01 PM   #3
DIY staff
Rewards Points: 7,174
You need to learn how to use a hand scraper----
There are two types used by floor finishers---the hooked scraper and the flat scraper---
A hooked scraper is the one you find in the paint section of the store---long plastic handle and a blade that can be turned 4 times before you need to sharpen.
Press and pull---when sharpened correctly will remove a lot of material fast--
A flat scraper (cabinet scraper) is a flat square of tempered steel---a burr edge must be added by you--using a steel rod rubbed over the edge of the sheet until a tiny burr is formed along the edge--
You tube will help you there---that tool removes a fine curl of wood--no sanding is needed after using a cabinet scraper--the wood will be smoother than any sander can achieve.
DangerMouse (03-06-2012)
Old 03-06-2012, 09:04 PM   #4
DIY staff
Shellac --that's what's gumming up the paper---nasty to sand off--clogs up paper faster than you can buy it---
Old 03-06-2012, 09:16 PM   #5
Rewards Points: 12,790
http://images.search.yahoo.com/image...mb=cpCLpHoH11V
Old 03-06-2012, 09:18 PM   #6
Old 03-06-2012, 09:33 PM   #7
i've read about hand scraping corners and always pictured this:
http://www.toolup.com/images/Product/large/SCR-L300.jpg
your's make a whole lot more sense to me
sevenlol is offline   Reply With Quote
Old 03-06-2012, 09:44 PM   #8
DIY staff
Joes picture is the one---keep a flat file in your back pocket to sharpen it--or cheat and use your belt sander---I'll see if I can dig up an image of a cabinet scraper--
Tags
corner , sanding , wood floor
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 04:14 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 05:30 AM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
