Can You Run Laminate Over Old Linoleum Glue? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-22-2010, 01:53 PM   #1
Can you run laminate over old linoleum glue?
I have a layer of linoleum over really old vinyl. I'm putting laminate down over that room and an adjoining room. In order to have less of a transition into the linoleum room I was thinking of removing the linoleum (it comes up pretty easily), but there is no way I can remove the vinyl. Problem is that the glue from the linoleum is stuck on the vinyl. Can I run the laminate right over that without any problems?
Thanks!
Player is offline   Reply With Quote
Old 06-22-2010, 02:05 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 14
Be aware, there is a chance the linoleum contains asbestos. If the floor is sticky when you get the lino up, sprinkle baby powder over it. That will keep your floating floor from sticking to it.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 06-22-2010, 02:17 PM   #3
Handyman
Rewards Points: 512
Good thought but I wonder what that might smell like over time. In any case the floor should still float as it is laid on top of underlayment. The underlayment, however, is "stuck" there
canadaclub is offline   Reply With Quote
Old 06-22-2010, 02:31 PM   #4
Rewards Points: 14
Been sprinkling baby powder on sticky floors for 40 years. Never had a complaint. Certainly makes it easier to walk on and work.
Old 06-22-2010, 03:16 PM   #5
Handyman
Rewards Points: 512
Now that's a great point! Think I got your answer out of context.
Old 06-22-2010, 03:52 PM   #6
the Musigician
DangerMouse's Avatar
Never thought of baby powder when I had sticky floors to rip up. I just threw sawdust on them, walked it in and swept it up when I was done. Dunno how that'd work for you though.
DM
Old 06-22-2010, 04:00 PM   #7
Rewards Points: 14
I always had baby powder on the truck anyway. Back in the old days, carpet pad had no skim on top. If you wanted carpet to stretch easier, you sprinkled baby powder on the pad so the carpet would slide when it was stretched.
Old 06-22-2010, 04:05 PM   #8
the Musigician
I remember my 'boss' doing that when I was doing carpet laying.
DM
Old 06-22-2010, 04:19 PM   #9
Great idea! My underlayment is actually attached to the bottom of the laminate...do you think that will cause a problem?
Any suggestions to make the transition from the subfloor to the glue-topped vinyl go more smoothly?
Did you ever have any problems with smells using this method (from either the glue or the baby powder...although I imagine the glue is a lot stronger smell)?
Old 06-23-2010, 02:16 PM   #10
Handyman
Rewards Points: 512
I love this site..learn something new everyday
It doesn't matter that the underlayment is stuck. In fact sometimes its necessary to staple it down around corners or patches.
Old 06-23-2010, 02:57 PM   #11
The underlayment is a actually attached to the bottom of the laminate. The manufacturer doesn't recommend using anything else under the underlayment unless it is really sturdy. Do you think I'll have any problems with the floor floating and moving over the baby powdered linoleum glue?
Old 06-23-2010, 03:47 PM   #12
Handyman
Rewards Points: 512
Your floor is floating over the underlayment. No worries..rock on.
Old 06-23-2010, 03:49 PM   #13
But the underlayment is attached to the laminate so it will be floating and moving with the laminate. Does that make sense?
Old 06-23-2010, 04:16 PM   #14
Handyman
Rewards Points: 512
The laminate should be attached to nothing, hence, floating. Was this a tear out? The underlay is put down to provide a gliding surface for the floor to expand and contract without splitting the joints. It matters not if the underlayment is attached or just lying flat.
The only difference is in basement installs (which I never recommend) where there is a built in vapour barrier but same rules apply
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
Laminate Flooring - glue removal armsteadj1 Flooring 1 12-16-2009 01:21 PM
Best glue for plywood laminate? cvriv.charles Building & Construction 2 07-13-2009 10:03 PM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 01:04 AM
Laminate flooring over old glue?? TomC723 Flooring 2 08-19-2008 01:33 AM
