Can You Really Waterproof Laminate Flooring? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-17-2013, 03:37 PM   #1
Rewards Points: 452
Can you really waterproof laminate flooring?
I don't remember where I read it, but someone said he used motor oil along the edges of laminate planks before clicking together, and that makes it water resistant.
I wonder why mfgr's still haven't figured out how to waterproof this stuff.
pet pee, water spills... you pretty much can't even use it.
pman6 is offline   Reply With Quote
The Following User Says Thank You to pman6 For This Useful Post:
fortner (04-17-2013)
Old 04-17-2013, 04:23 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 388
Logic tells you it's impossible to waterproof the stuff. The back is made from compressed wood fibers or wood chips. It's a bunch of planks butted together, how can it be waterproof?
I don't think anyone really expects it to be waterproof. if so, I've got a bridge.
Jaz
Old 04-17-2013, 05:00 PM   #3
Floor Installer
sam floor's Avatar
Rewards Points: 154
No, you cannot water proof it, period.
sam floor is offline   Reply With Quote
The Following User Says Thank You to sam floor For This Useful Post:
joecaption (04-17-2013)
Old 04-17-2013, 05:09 PM   #4
Rewards Points: 13,712
Other then peel and stick tile flooring there is no other flooring that will lower the resale value of a home faster then laminite flooring.
There's no way to "waterproof" lamininte flooring,
No way would I suggested using it below grade, in a kitchen or bathroom.
Using motor oil
That has to be a joke. Or a suggestion from someone that has no clue.
Old 04-17-2013, 05:32 PM   #5
Rewards Points: 4,796
Waterproof and water resistant are 2 different things.
Generally, I don't think laminate flooring really has to be waterproof. Just because something spills on it doesn't mean it will swell up. Thousands of laminate floors are doing just fine. My kitchen has laminate, has endured many spills, and looks the same as it did 5 years ago.
It's not as water resistant as tile, or even hardwood floors with the very tight spacing. However like everything else, laminate floors are coming along. Here's a product I'm looking forward to trying, but haven't yet. It is wax coated (sides, not the surface) and looks much more water resistant than standard.
http://www.builddirect.com/Laminate-..._10078496.aspx
Here's some water resistance data
This comes in 18mm thickness! This is roughly the same as standard hardwood flooring. Watch the video at the bottom. In one hand he has a 12mm board, and in the other a 15mm. So you can imagine the thickness of 18mm. (He says 15mm is the thickest they make, so obviously the video is outdated.)
jeffnc is offline   Reply With Quote
Old 04-17-2013, 07:49 PM   #6
Rewards Points: 452
it's either this, or floating vinyl plank, and they both suck in some way.
I'm not putting this in the kitchen, where I already have ceramic tile.
Tenants are always careless, and leave spills or animal piss lying around.
laminate thickness doesn't really matter if the wear layer is crap.
Old 04-17-2013, 08:48 PM   #7
What makes you think the wear layer sucks? And why would you tear out tile to put down laminate?
Thickness is for feel and sound deadening. The earlier laminates sometimes sounded like you were walking on plastic.
laminate flooring over laminate flooring bowbender6 Flooring 6 07-04-2012 09:27 PM
Laminate Wood flooring for duplex jukeboxpunk Flooring 16 06-23-2012 04:39 AM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 02:55 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 08:35 PM
