Can You Lay Travistine Tile Over Vinyl Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 07-20-2011, 09:40 AM   #1
can you lay travistine tile over vinyl tile
We have vinyl tile in a foyer and want to lay travestine over it, how to do it and can it be done
Saik, C is offline   Reply With Quote
Old 07-20-2011, 09:58 AM   #2
Thadius856's Avatar
Rewards Points: 504
I can't think of any reason why you'd want to put a very nice, expensive, heavy, labor-intensive travertine install over top of vinyl. I imagine that the mud wouldn't stick well to the tiles, unless the top coating layer was completely removed and the tile was very well scored. Even then, you could run into problems with the vinyl sliding around, as your mud might cause the adhesive of newer tiles to become liquid again. Especially if these are the sticky 12" kind that come in a box.
I'd highly recommend removing the tile and scraping up any remaining adhesive before you start. It will probably save you time and headaches in the long run.
Thadius856 is offline   Reply With Quote
Old 07-20-2011, 01:34 PM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
There are a lot of criteria to consider before laying tile. Subfloor, deflection, etc. etc. But lets start with this. Take a piece of tile (or something of the same thickness) and place it on the floor in front of the door. Open the door. If the door pushes it out of the way you will have to address this issue as well.
Tiling over vinyl is not a good idea, but whatever you decide, don't forget to account for any change in thickness and how it will affect doorways, transitions to other flooring, etc.
Old 07-20-2011, 01:48 PM   #4
Experienced
Jackofall1's Avatar
Putting stone down on exiting tile floor is an absolute no no.
There are many steps to get to the part of actually laying the tile, you should do some research on the subject, it is labor intensive and requires the right procedures for it to last.
Mark
Old 07-20-2011, 05:59 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
There are necessary requirements your floor structure must meet before you think about installing any stone tile. Most floor structures aren't suitable without some modifications.
XXX
Old 07-21-2011, 09:21 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 424
That would be a travesty.
Kidding aside, that would not be the smartest thing you've ever done. I guarantee you will have more pieces shortly after installing that way than you first installed.
Jaz
Old 07-21-2011, 09:28 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Travistine = travesty!!!
I see you caught it also Jaz.
XXX
Old 07-21-2011, 09:36 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 424
Boy Bud you are sharp and working overtime too. I've been slacking off a bit lately. Kinda hot all week, (100 today), riding my bike every evening to try to stay in shape. And........oh.... the pool.
Jaz
Old 07-21-2011, 10:02 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The truth is I burned out and had to take some time off, so I've been attending to my honey-do list for the past month and hangin' out here. Sorry to say it's back to work on Monday. Just can't put it off any longer.
XXX
Old flooring / installing new vinyl tile gwelton Flooring 2 06-24-2009 03:10 AM
Vinyl Tile Over Hardwood LGrey Flooring 1 02-16-2009 10:34 AM
Tile over vinyl hmc Flooring 7 10-25-2005 11:05 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
