Can You Install Tile On Top Of Tile? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-30-2010, 11:08 PM   #1
Rewards Points: 79
Can you install tile on top of tile?
What would you do? (pic below)
This is just a basic rental house... so i dont want to spend big bucks.
ehoez is offline   Reply With Quote
Old 10-01-2010, 08:48 AM   #2
Rewards Points: 106
[quote=ehoez;509643]Can you install tile on top of tile?
You most certainly can; I have seen it done numerous times.
I would NOT install tile over tile. I would remove the stool and vanity, get busy stripping, check that the floor is not rotteed, and if it is, repair as necessary, install the new tile, and set the stool and vanity back in place. Only additional expense is the cost of a new wax ring. Many times, you will spend less time R&Ring the stool and vanity than you would by leaving them in place and cutting tiles to fit around them.
Old 10-01-2010, 09:15 AM   #3
Rewards Points: 558
Yes, you can install tile over tile. Removing old tile can cause damage to the wall and create more work than just installing tile over tile. Depending on where you want to install the tile will determine what you need to do to prepare the surface for re-tiling.
But remove the toilet and raise the flange then install the new tile.
epson is offline   Reply With Quote
Old 10-01-2010, 01:42 PM   #4
Rewards Points: 156
Just based on the picture, I'd give it a real good cleaning and leave it alone. It looks like it's pretty much intact and serves the purpose of a bathroom floor.
if it's just a "basic rental" there's not really any value gained in replacing a functioning floor. It's not like the style of the bathroom floor is going to be a deal-breaker for a renter.
moondawg is offline   Reply With Quote
The Following User Says Thank You to moondawg For This Useful Post:
ehoez (10-01-2010)
Old 10-01-2010, 03:51 PM   #5
Rewards Points: 79
true.. thanks
but that cabinet , gots to go, lol
Old 10-01-2010, 03:54 PM   #6
Rewards Points: 156
Originally Posted by ehoez View Post
true.. thanks
A good coat of paint would probably go a long way!
Old 10-01-2010, 04:05 PM   #7
Rewards Points: 79
now i just gotta fix the kitchen too, lol
Old 10-01-2010, 07:37 PM   #8
be careful
The tile appears to be installed over a mud bed. That is the only way you can get mosaic tile to lay that flat. You are going to find an inch or more concrete over metal lath under it. It is a mess to take out. You can install over it if it is all sound. Clean the tile with a good tile and grout cleaner and install over it with modified thinset. You will have an increase in floor thickness of about 1/2 inch by going over it. That may cause problems at the door.
floorinstall is offline   Reply With Quote
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 04:39 PM
Help for Tile install. Cork underlayment? andy1908 Flooring 8 06-04-2009 02:54 PM
Install tile over vinyl billyg Flooring 1 12-26-2008 12:26 PM
Tile Cutter vs. Tile Saw jamiedolan Flooring 8 11-09-2008 03:17 AM
Cost to install dropped ceiling tile??? timthetoolman Building & Construction 4 06-08-2008 09:06 PM
