Can Portland Cement Be Used Instead Of Floor Leveler? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-22-2010, 11:08 AM   #1
Can Portland Cement Be used instead of Floor Leveler?
Just curious if I can use portland cement instead of floor leveler? Floor levler is extremely expensive and it says it contains portland cement. I have a plywood floor (3/4") That is slightly out of level where the boards meet. I want to use portland cement to even it out. I plan to put down hardee board and tile. The area that is bad is under the vanity anyway so its not really visible. Just curious if portland cement is ok for this. Should I use thinset instead?
jonathan03 is offline   Reply With Quote
Old 07-22-2010, 11:12 AM   #2
concretemasonry's Avatar
Rewards Points: 2,570
No, not by itself.
concretemasonry is online now   Reply With Quote
Old 07-22-2010, 11:17 AM   #3
How about mixing portland cement and mortar? Anything cheaper than floor leveler?
Old 07-22-2010, 11:23 AM   #4
Rewards Points: 271
You could probably use some form of portland but make sure you use latex bonding agent in the mix. Is it a big area?
Frank Lardino
FrankL is offline   Reply With Quote
Old 07-22-2010, 11:25 AM   #5
The area is 1'x2' and its sunk about 1/4". I just cant to fill in the hole.
Old 07-22-2010, 04:47 PM   #6
DIY staff
Rewards Points: 7,174
Portland by itself will not bond--Some people use a layer or thinset and let it dry .
I have not tried that--however.
The hardy absolutely must have thinset under it to fill voids--you are going to have a bag of it for that
you could take a chance,---Mike---
Old 07-22-2010, 04:58 PM   #7
For such a small area, you only need a kid's bucket of fine sand (to give it body) and a latex additive to make it stick. Use as little water as possible and go over with a floor leveler.
Dick
The Following User Says Thank You to concretemasonry For This Useful Post:
oh'mike (07-22-2010)
Old 07-22-2010, 05:04 PM   #8
Rewards Points: 271
Thinet and some bonding agent should do the trick.
Frank Lardino
Old 07-22-2010, 09:42 PM   #9
Tile god
use some thinset, let it dry ,then carry on. I prelevel with thinset all the time
the tile guy is offline   Reply With Quote
Old 07-23-2010, 12:21 AM   #10
Civil Engineer
Rewards Points: 4,518
You may be confusing portland cement with concrete. Portland cement by definition is the cementing agent used in concrete, and in certain types of mortar. Concrete also includes sand, aggregate and water, while mortar includes sand and water, no aggregate.
Portland cement by itself is very weak, I would never use it under tile. Mortar is much stronger, and perfectly suitable for use under tile as noted by others. Concrete is typically not used because the aggregate is too large for use under tile.
