Can Linoleum Be Painted? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-12-2011, 07:25 PM   #1
Caution! Girl working
can linoleum be painted?
Hi! Do you think linoleum basement flooring can be painted? It's a walk-out basement that tends to be humid in the summer, but the dehumidifier keeps up pretty well. The linoleum is very old, has no shiny finish, and is not cracked or peeling up at all. The room will be used as a functioning art studio, so knife blades, tiny shards of glass, cleaning chemicals, water, and assorted other things will end up all over the floor, which I'm OK with. It's going to get banged up and doesn't have to look perfect.
The acrylic paint I spilled stuck very well and I've been walking on it for a couple of weeks and it's not coming up at all, which makes me wonder about whether painting would be a good alternative.
Because of the water and teeny-tiny shards of glass that fall from the stained glass grinder, laminate, cork, and any flooring options that have seams are a poor choice. I could do a new sheet of linoleum, but knife blades tend to fall sometimes and it probably wouldn't be long before the new flooring was ripped.
Since there's a slab of cement under the linoleum, will the linoleum act as an appropriate moisture barrier if I paint it? What type of paint would be best, and do I need an adhesive primer? Also, does it need polyurothane on top or is that not recommended?
THANK YOU!
ADaniLion is offline   Reply With Quote
Linoleum not flush against tub bottom? shub Flooring 5 05-31-2011 10:59 PM
20x20 Porcelain Tile over Linoleum on Concrete Slab scbauer Tiling, ceramics, marble 3 08-31-2010 07:11 PM
Old linoleum and new ceramic tile tmramrod91 Flooring 0 07-25-2010 07:39 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
Removing Vinyl Tile Adhesive from Linoleum The Raven Flooring 3 07-22-2008 08:38 PM
