Can I Use White Oak Risers For 42" X 48" Landing? Or Bad Idea? - Flooring - DIY Chatroom Home Improvement Forum
Old 12-16-2013, 01:01 AM   #1
Rewards Points: 152
Can I use white oak risers for flooring on 42" x 48" landing? Or bad idea?
I put white oak treads on my stairs & am trying to figure out what to do with the landing. I don't want to spend a lot of money so I want to do it myself.
I don't like the engineered hardwood floors or even the prefinished solid hardwood floors out there (I especially don't like the beveled edges, but none of them come out as nice as I'd like). I'm not sure I'm up to buying unfinished 3 inch or narrower strips of flooring, and I really don't want the expense of getting a nailing gun, but I might change my mind. One thought I had is to buy 3/4 inch x 7 inch wide white oak risers (I think these are made from factory glued oak strips) and use those for the flooring. I'd finish them with Bona DTS & then Bona Traffic (used on the treads) so it would have a good hard finish on it). The nice thing is the finish would match the treads perfectly!
I'm guessing one concern is expansion & contraction, and the fact that flooring probably fits together (tongue & groove) the way it does for a reason. Can I make this idea work so it looks nice for 10-15 years, or is it a real bad one?
lazzlazz is offline   Reply With Quote
Old 12-16-2013, 06:36 AM   #2
DIY staff
Rewards Points: 7,174
Sure you can add oak to the landing---I suggest you use standard tongue and groove flooring and a premade stair nosing.
For such a small area,hand nail it----another possibility is the use of a finishing gun--shoot into the tongue on an angle--
Old 12-16-2013, 11:16 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 190
Be aware that wide boards can cup and will shrink more than small boards. You can rip the boards down and spline them instead of T&G if you want to.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 12-16-2013, 07:56 PM   #4
woodman58's Avatar
The WO will work. It sounds like the risers are glued strips of oak. It will be a bit more stable than a solid board. But, being that wide, it will have to be glued down to keep it from cupping. If you're not planning on sanding it, you will have to use a piece of wood to keep them level. Tap them across the joints.
I LOVE THE SMELL OF SAWDUST IN THE MORNING!
woodman58 is offline   Reply With Quote
Old 12-17-2013, 02:54 AM   #5
Rewards Points: 152
Thanks for all the advice! I'm not quite ready to start the project but I'm sure I'll have plenty of questions if I end up using the white oak risers. I assume I can nail a layer of 1/4 inch plywood over the subfloor & glue the risers to the plywood, to prevent cupping. I've never done a glued floor so I'm going to show my ignorance: do I use a wood glue, or is there a certain kind of glue I need. Any recommendations here are welcome!
Old 12-17-2013, 05:15 AM   #6
DIY staff
Bostichs Best wood floor adhesive---call a hardwood supplier---White oak flooring is not to expensive and will yield a good result---
Old 12-17-2013, 09:08 AM   #7
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Are you refinishing existing stairs?
One important concern is the depth of the material.
Changing materials with different thicknesses will create a trip hazard. Not a good thing on stairs.
The Following User Says Thank You to Blondesense For This Useful Post:
BigJim (12-17-2013)
White Stair Risers Paint ? ( 17 ) deck hand Painting 6 02-05-2013 11:12 PM
White stain instead of white paint on a piece of furniture? jbeall Painting 7 01-20-2013 07:47 PM
Putting color onto white brick or textured walls (need color suggestions!) Eliana Interior Decorating 2 01-18-2012 08:27 PM
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
