Can I Use Tile Adhesive Over Old Mortar To Fix Loose Tiles? - Flooring - DIY Chatroom Home Improvement Forum
Old 10-13-2012, 11:14 PM   #1
Rewards Points: 14
Can I use tile adhesive over old mortar to fix loose tiles?
I did my floor tile project a year ago. I have 2x10 floor joists at 16” on center spanning 12’. My subfloor is two layers of plywood, ” on bottom and 5/8” on top. I mortared and screwed down ” cement board as a base for my tile. I used a 1/2" square notch trowel with modified thin set to set the tiles. Based on the tiles I pulled up, my mortar coverage was only about 60% to 80%.
I have a few of my 18" porcelain tiles that are loose near where I rolled by refrigerator around a few times. The grout did not crack at all. I only noticed a few were loose by occasionally hearing a slight noise when I stepped on them.
The think the issue is that my coverage wasn’t good enough. Also I did not back butter them which didn't help any.
Will it work to just spread a thin layer of tile adhesive using a thin triangular notched (about 1/8" triangular notches) shaped floor adhesive trowel right over the old mortar? I was also kicking around first spreading mortar over the areas without coverage to have a totally flat and solid base and let dry. Then apply the adhesive to have a 100% solid flat base to work on.
Alternatively, I could just chisel off the old mortar and try again with better coverage.
Also, any tips on how to keep the fridge from hurting the tile? I was thinking of rolling the fridge around on 3" wide by 1/8" thick steel plates to help distribute the load better.
Thanks.
JFERTICH is offline   Reply With Quote
Old 10-13-2012, 11:20 PM   #2
Rewards Points: 13,270
If there's a proper subfloor, underlayment 1/4 cement board and the thin set was apply correctly the ref, should have no effect on the tiles. Somethings wrong if there poping loose.
Problems with Omni Grip tile adhesive Blue Flooring 24 05-15-2016 08:37 PM
Tile Roof - To offset or not to offset tiles kowtow Roofing/Siding 3 12-07-2010 11:17 PM
Adhesive for large ceramic tile over concerete slab GeauxCajuns82 Tiling, ceramics, marble 2 11-18-2010 06:13 PM
tile saw advice for 24" porcelain tiles diy'er on LI Tiling, ceramics, marble 12 10-11-2009 04:34 PM
Tile Over Adhesive newbsauce Flooring 2 09-26-2009 11:45 AM
