Old 02-19-2011, 05:56 PM   #1
Can I use Thin Set Mortar over Interior Grade Plywood?
I am planning to add 1/4" cement board and tile to my subfloor. My subfloor consists of two layers of 1/2" to 5/8" plywood. The plywood was manufactured in 1983 and is marked C-D exposure 1, which I think means it is an interior grade plywood.
All the literature I read on applying thin-set is that it is only recommended for exterior plywood. I heard that applying wet thin set mortar over interior grade plywood could cause plywood delamination.
Should I paint or possibly seal the plywood surface with something first or just apply the thin set mortar down directly over the plywood and don't worry about it?
Also the plywood is very tight fitting with no gaps between sheets. Is that ok?
JFERTICH is offline   Reply With Quote
Old 02-19-2011, 06:08 PM   #2
Super Moderator
Not a worry.
The thinset will not delaminate the ply----Go for it.
I've done this countless times without a problem.----Mike---
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 Today 02:04 PM
coverin plastic tile wall with panelin or thin plywood. how to cover the seams? chinolofus Remodeling 2 11-23-2010 07:52 PM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-14-2010 12:09 AM
Basement Concrete Block Mortar Seepage Advice Nightcrawler Building & Construction 6 09-22-2009 09:57 PM
Mortar or thin set for brick pavers bdawson General Discussion 0 04-27-2008 02:44 PM
