Can I Use Regular Finishing Nailgun - Flooring - DIY Chatroom Home Improvement Forum
Old 01-07-2010, 03:58 PM   #1
Rewards Points: 154
Can I use regular finishing nailgun
to install hardwood floors? I have the dewalt 618 series and it seems to be the same as a pneumatic gun.
llckll is offline   Reply With Quote
Old 01-07-2010, 04:11 PM   #2
jlhaslip's Avatar
Rewards Points: 980
It can be done, but it would not be recommended. Those are 18 guage nails so you would need to put several times more of them in to do the same job as an 'l-cleat' or staple. Rent the tool if you must.
What sort of flooring are we taking about? solid wood or an engineered product?
jlhaslip is offline   Reply With Quote
Old 01-07-2010, 04:13 PM   #3
Rewards Points: 154
Thanks. I would like solid wood but depends on the price. I am doing my initial research and will most likely start in the spring.
Old 01-07-2010, 04:15 PM   #4
I used 15 guage finish nails to put down a bamboo floor (the instructions said it was OK). It seems to have worked find.
I think with a regular wood you'd have more problems with squeeks and stuff. the bamboo I used is the kind with flat strips laminated in three layers. It's very uniform and pretty stable.
pyper is offline   Reply With Quote
Old 01-07-2010, 04:17 PM   #5
Rewards Points: 154
Underneath my existing floors is a baseboard. Some areas are very warped so i'll probably have to put new baseboards in those areas.
Did you use underlayment when laying new floors? What are your thoughts on cork underlayment as well?
Old 01-07-2010, 07:22 PM   #6
jlhaslip's Avatar
Rewards Points: 980
pyper, yes, an engineered product would be more stable, so a 2 1/2 " 15 guage would work.
llckll, i've never put new sub-floor under hardwood flooring. How thick and what type of sub-floor is there now?
as to the cork, check with the flooring source once you decide on the type.
Old 01-09-2010, 07:25 PM   #7
Rewards Points: 154
I'm not sure what kind of sub-floor. But the floor by my balcony door is very warped/uneven. I suppose I'll find out when I get there.
Finishing drywall behind kitchen cabinets LeviDIY Drywall & Plaster 1 08-24-2009 05:00 PM
Basement Finishing Advice Wanted PJU1971 Carpentry 4 04-04-2009 05:04 PM
Question about regular & high speed USB's mact60 PC Repairs & Upgrades 3 08-01-2008 06:55 PM
Resilient Channels and finishing drywall 9728 Building & Construction 5 06-08-2007 09:32 AM
Finishing nail removal bklauer Carpentry 6 09-05-2006 08:13 AM
