Can I Use Caulking On Laminate Floors? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-29-2008, 11:09 PM   #1
Can I use caulking on laminate floors?
After I get my laminate flooring down is it alright to use caulking in the space between floor and the wall and around the water pipes and drain to help keep the bugs out? They come straight up out of the floor. Also, I am installing the floors in the laundry room that is not concrete, do I need the padding that has the moisture barrier on it or can I use just the foam padding? Thanks
Last edited by jdubya; 08-29-2008 at 11:11 PM. Reason: I left something out of my post
jdubya is offline   Reply With Quote
Old 08-29-2008, 11:12 PM   #2
Registered User
Termite's Avatar
You can use regular padding if you're not laying it on a concrete floor.
Caulking around your pipe penetrations would be a good idea. Use a flexible caulk like bathroom silicone.
Old 08-30-2008, 04:14 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
TheKCT answered your questions, tho, just like to add:
Generally, using a floor color similar caulking is what the majority of laminate flooring manufactures state in their installation instructions.
The foam with MR barrier is primarily a better material, in specific installations installations. Example: Over concrete. Otherwise, as stated, the foam without MR is fine...
- Build Well -
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
Putting laminate floors upstairs..what should I do with my stairs genyaf Flooring 4 01-02-2008 11:52 PM
Buckling of Laminate floors branjack Flooring 13 12-26-2007 01:38 PM
Joining laminate floors of different height. flyingmachine Flooring 5 09-13-2006 09:59 PM
Sound Guard and laminate floors ck1 Flooring 5 01-15-2006 06:09 PM
