Can I Undercut/grind Granite? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-18-2010, 04:21 PM   #1
Rewards Points: 150
Can I undercut/grind granite?
I'm laying 3/4" oak hardwoods. I am trying to figure out a gameplan for the fireplace slab - I think it is made of granite (granite or marble). As it sits now, the floor strips are only a couple of millimetrs taller than the botoom of the slab. I would like to get the "clean" look by going underneath this grante slab. Do you think it's safe to grind a way this small difference? I'm afraid of cracking the entire piece. (I promise to wear safety goggles).
joemontana16 is offline   Reply With Quote
Old 01-18-2010, 05:03 PM   #2
rabbit top of flooring to slide under then scribe finished face to fit. each run should start from hearth
Old 01-19-2010, 11:07 PM   #3
I have under cut granite but not very deep. So if you are gluing your wood down you dont need as expantion room. If you are floating your wood you need to install a transition strip around your mantle.
just tile is offline   Reply With Quote
Old 01-20-2010, 11:26 AM   #4
The fellow who put in my hearth said that if my wood wouldn't go under the stone, to call him back and he would undercut it for me. Everything fit, so I have no idea how it would have worked, but he indicated it would be an easy thing.
pyper is offline   Reply With Quote
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 12:44 PM
Granite Hearth/Saltillo tile transtion help SeminoleMike Flooring 2 02-08-2009 12:49 PM
Granite not installed correctly???? debsc Kitchen & Bath Remodeling 7 02-01-2009 09:58 AM
Decorative Etched Granite Listello csteinke Remodeling 1 06-09-2007 12:54 AM
