Old 07-21-2008, 08:18 AM   #1
Question
can I just stain and poly my old wood floors?
I bought this old house and the floors actually look good, not alot of scuffs and no paint but, the color is lighter than I want and it doesnt have hardly any shine to the wood would it be okay to just stain it a darker cherry color and then use polyurethane coating without sanding any?
hollyworthy is offline   Reply With Quote
Old 07-23-2008, 11:43 AM   #2
Another DIY Zombie
Thinking that for best results, you should sand down to bare wood, then stain / refinish , etc.
Depending on the size, I have heard of good results from just using a palm sander....Then again, I have also heard of bad results too.
If it were me (and it was with two floors), I would rent the floor sander (not a drum sander) and sand the floor / refinish yourself. The heavy duty sander will make the job much easier.
javan is offline   Reply With Quote
Old 07-23-2008, 02:29 PM   #3
Smile
Thanks that is what I was probably going to end up doing, with a two year old its so impossible to do stuff like that, I guess I was just not looking forward to doing it ha ha!
Old 07-23-2008, 02:55 PM   #4
Another DIY Zombie
Too True, but then again, you will be much happier with the results....
painting over a wood stain franko24 Painting 5 10-13-2010 08:52 PM
Miniwax one step stain and poly!!! Good? KUIPORNG Remodeling 6 10-17-2007 11:53 AM
Finishing Cabinets -- Wow. Need advice! Patriot_RAM Painting 15 08-09-2007 10:55 PM
Drum Sander -vs- Disk Sander BlueGuy Flooring 7 08-20-2006 10:44 PM
